Full Version: TVH crashes every time
I've the following problem.
every time if I wake up or reboot my HTPC with KODI 17.1 and try to play a PVR chanal KODI crashes.
omly workaround I figured out is to make some changes in TVH settings so that the PVR-service need to restart.
after that I can start every chanal again...
yesterday I made a fresh install from Kodi and TVH-backend and restore with backup-addon but same issue
so I delete the /userdate/addon-date forlder of TVH to clean all settings but it did not help
Server:
Ubuntu 14.04.
TVH 4.1-2301
client:
Ubuntu 16.04
Kodi 17.1 RC1 GIT20170223
pvr-hts 4.4.17
14:01:04.905 T:140359554820480   DEBUG: Loading settings for pvr://channels/tv/Alle Kanäle/pvr.hts_1600446656.pvr
14:01:04.907 T:140359554820480   DEBUG: CPlayerCoreFactory::GetPlayers(pvr://channels/tv/Alle Kanäle/pvr.hts_1600446656.pvr)
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
14:01:04.907 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
14:01:04.908 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
14:01:04.908 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
14:01:04.908 T:140359554820480   DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
14:01:04.908 T:140359554820480   DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
14:01:04.908 T:140359554820480   DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (VideoPlayer)
14:01:04.908 T:140359554820480   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
14:01:04.908 T:140359554820480   DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
14:01:04.908 T:140359554820480   DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
14:01:04.910 T:140359554820480   DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData
14:01:04.910 T:140359554820480  NOTICE: VideoPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.hts_1600446656.pvr
14:01:04.910 T:140359554820480 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
14:01:04.910 T:140359554820480   DEBUG: LinuxRendererGL: Cleaning up GL resources
14:01:04.933 T:140359554820480   DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16
14:01:04.933 T:140356103636736   DEBUG: Thread VideoPlayer start, auto delete: false
14:01:04.934 T:140356103636736  NOTICE: Creating InputStream
14:01:04.934 T:140356103636736   DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'Das Erste HD'
14:01:04.934 T:140356103636736   DEBUG: opening live stream for channel 'Das Erste HD'
14:01:04.934 T:140356103636736   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux open
14:01:04.934 T:140356103636736   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux subscribe to 1600446656
14:01:04.934 T:140356103636736   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux successfully subscribed to channel id 1600446656, subscription id 1
14:01:04.934 T:140356103636736   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux subscribe to 762890067
14:01:05.402 T:140356469368576   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unhandled subscription message [subscriptionGrace]
14:01:05.402 T:140356103636736   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux successfully subscribed to channel id 762890067, subscription id 2
14:01:05.402 T:140356103636736   DEBUG: CDVDInputStreamPVRManager - Open - playback has started on filename pvr://channels/tv/Alle Kanäle/pvr.hts_1600446656.pvr
14:01:05.402 T:140356103636736   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/Alle Kanäle/pvr.hts_1600446656.pvr
14:01:05.402 T:140356103636736  NOTICE: Creating Demuxer
14:01:05.402 T:140356103636736   DEBUG: OnPlayBackStarted: play state was 1, starting 1
14:01:05.402 T:140356103636736   DEBUG: CVideoPlayer::SetCaching - caching state 2
14:01:05.402 T:140356103636736   DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
14:01:05.402 T:140359554820480   DEBUG: PlayFile: OpenFile succeed, play state 2
14:01:05.402 T:140359554820480   DEBUG: OnPlayBackStarted: play state was 2, starting 0
14:01:05.408 T:140359060772608   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
14:01:05.409 T:140356283430656   DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Alle Kanäle/pvr.hts_1600446656.pvr)
14:01:05.409 T:140359060772608   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
14:01:05.434 T:140357912225536   DEBUG: Skin Helper Service --> Kodi_Monitor: sender xbmc - method: Player.OnPlay  - data: {"item":{"channeltype":"tv","id":120,"title":"Das Erste HD","type":"channel"},"player":{"playerid":1,"speed":1}}
14:01:05.445 T:140357786400512   DEBUG: script.toolbox: blurred img already created: /home/kodi/.kodi/userdata/addon_data/script.toolbox/48b9de8b2eb6c9885a2db423b1d404fb30.png
14:01:05.492 T:140357887047424   DEBUG: Skin Helper Widgets --> Kodi_Monitor: sender xbmc - method: Player.OnPlay  - data: {"item":{"channeltype":"tv","id":120,"title":"Das Erste HD","type":"channel"},"player":{"playerid":1,"speed":1}}
14:01:05.498 T:140357786400512   DEBUG: script.toolbox: Average Color: FF4f71c7
14:01:05.910 T:140356469368576   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unhandled subscription message [subscriptionGrace]
[/align]
same here .. using openelec on rpi2 and at least after a day or two either tvh or kodi completely hangs
