Full Version: Double clock when large menu selected
Hi all,
I setup Titan with the Netflix style home screen layout and large menu size. I noticed that this produces an additional clock on the top bar when the menu is not visible. When the menu is visible the second clock moves over on top of the original clock so only one is visible. It's as if the menu has a partial top bar of it's own attached to it. Has anyone else noticed this and is there a way to eliminate the partial top bar containing the additional clock?
Thanks,
Dee
same problem in 3.7.56 [stable] but no longer in 3.7.58 [beta]. can you verify this please
Checked beta 3.7.59 but still has the issue. I am on a Nvidia Shield.
This will be fixed in next beta update
