Full Version: Kodi 17.1 Kodi quit unexpectedly.
Pages: 1 2
Hi
Can someone help please, I have just did a factory reset and removed my old Kodi to install the new version 17.1
When I open the Kodi Icon, I get Kodi quit unexpectedly.
See my Paste bin below
https://pastebin.com/7tns9pZN
Thank in advance
H
You will need at least OS X 10.8 to run Kodi 17 or higher.
I have done the same and am having the same problem and I'm running version 10.12.4. Any suggestion?
I'm having the same problem. On OS 10.12.4.
Thank you @Rechi, that worked perfectly
i am on OSX 10.12.4 and i am having the same issue. HELP
Maybe http://forum.kodi.tv/showthread.php?tid=311058 is the solution.
If it doesn't solve your issue, post a Debug log (wiki).
I have the same problem with kodi 17.1 on my MacBook Air - I'm running OS X 10.10.5
I get message " The last time you opened Kodi it unexpectedly quit while reopening windows "
when I try to reopen I get message " Kodi unexpectedly quit " and 3 options Ignore,Report or Reopen
Any suggestions on what to do please.
I've now got exactly the same problem with my iMac, I updated my OS X to 10.12.4 Sierra, installed kodi 17.1 Krypton from Jarvis and got
the same error message that I got on my MacBook Air, lucky a kept the old Jarvis install and this is running OK.
Help, surely this must be a problem unique to 17.1?
I'm not very technical so would appreciate a idiots guide type reply.
Have you tried the following?
(2017-04-08, 12:54)Rechi Wrote: [ -> ]Maybe http://forum.kodi.tv/showthread.php?tid=311058 is the solution.
I just tried it now and came unstuck at step 7. There is no folder in Application Support called Kodi or XBMC.
As in your link the error was [Addons27.db]. I have searched the computer and can not find a file with that name.
Thanks for you help on this.
R.
Please see my post above jimskid 2017-04-09
Finally resolved my problem, using Rechi's link above.
Many thanks
Is it possible that someone could post screenshots/video of the steps to fix this issue? I apologize if it seems like a bit much but a step 7 of the most recent "solution" I get stuck and don't really know where to go.
b7000 - it's not solved for me in that post. As mentioned above, there is no folder in Application Support called Kodi or XBMC.
Any other suggestions?
Pages: 1 2
