Hi to all, I'am a new user here.
Sorry for my bad english,
I have a problem with Filmweb scrapper in tmm v. 2.9.3.1, it's simply not working, don't scrap even movie title. i think, that webpage has changed.
TMM does not provide a FilmWeb scraper.
Are you a donator, and used the Kodi FilmWeb plugin for that?
Try if it works inside Kodi - fine, use it there.
If not, ask them...
So, can i copy plugin to tmm?
No, not needed.
We are just able to read and use them.
(and it looks like, you did already)
BUT we cannot provide support if it does not work.
Does this scraper plugin work inside Kodi?
ok, if you updated this scraper in Kodi to 2.3.5 (auto update?),
you should see the 2.3.5 in TMM->settings->movie->scraper...
No, i updated this scrapper manually - in KODI added new repository. In official repo is still version 2.3.0
In tmm is also version 2.3.0
ok, it works
I have to update this addon in LOCAL Kodi on my PC. Seems to tmm use scrapper from local kodi installed in the same machine.
Normally i use kodi on external qnap device.
