Here is my Kodi log
[quote]08:53:21.124 T:1945489408 NOTICE: special://profile/ is mapped to: special://masterprofile/
08:53:21.124 T:1945489408 NOTICE: -----------------------------------------------------------------------
08:53:21.125 T:1945489408 NOTICE: Starting Kodi (17.1-RC2 Git:20170312-b2013fd-dirty). Platform: Linux ARM 32-bit
08:53:21.125 T:1945489408 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
08:53:21.125 T:1945489408 NOTICE: Kodi compiled Mar 12 2017 by GCC 4.9.2 for Linux ARM 32-bit version 3.16.7 (200711)
08:53:21.125 T:1945489408 NOTICE: Running on Raspbian GNU/Linux 8 (jessie), kernel: Linux ARM 32-bit version 4.4.50-v7+
08:53:21.133 T:1945489408 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
08:53:21.134 T:1945489408 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
08:53:21.134 T:1945489408 NOTICE: ARM Features: Neon enabled
08:53:21.134 T:1945489408 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
08:53:21.134 T:1945489408 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
08:53:21.134 T:1945489408 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
08:53:21.134 T:1945489408 NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
08:53:21.134 T:1945489408 NOTICE: special://envhome/ is mapped to: /home/pi
08:53:21.134 T:1945489408 NOTICE: special://home/ is mapped to: /home/pi/.kodi
08:53:21.134 T:1945489408 NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
08:53:21.134 T:1945489408 NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
08:53:21.134 T:1945489408 NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi.bin
08:53:21.134 T:1945489408 NOTICE: Local hostname: raspberrypi
08:53:21.134 T:1945489408 NOTICE: Log File is located: /home/pi/.kodi/temp//kodi.log
08:53:21.134 T:1945489408 NOTICE: -----------------------------------------------------------------------
08:53:21.431 T:1945489408 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanSuspend
08:53:21.431 T:1945489408 ERROR: DBus: Error org.freedesktop.DBus.Error.InvalidArgs - No such property CanHibernate
08:53:21.448 T:1945489408 NOTICE: load settings...
08:53:21.653 T:1945489408 NOTICE: Found 2 Lists of Devices
08:53:21.653 T:1945489408 NOTICE: Enumerated PI devices:
08:53:21.653 T:1945489408 NOTICE: Device 1
08:53:21.653 T:1945489408 NOTICE: m_deviceName : HDMI
08:53:21.653 T:1945489408 NOTICE: m_displayName : HDMI
08:53:21.653 T:1945489408 NOTICE: m_displayNameExtra:
08:53:21.653 T:1945489408 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
08:53:21.653 T:1945489408 NOTICE: m_channels : FL,FR
08:53:21.654 T:1945489408 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
08:53:21.654 T:1945489408 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
08:53:21.654 T:1945489408 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
08:53:21.654 T:1945489408 NOTICE: Device 2
08:53:21.654 T:1945489408 NOTICE: m_deviceName : Analogue
08:53:21.654 T:1945489408 NOTICE: m_displayName : Analogue
08:53:21.654 T:1945489408 NOTICE: m_displayNameExtra:
08:53:21.654 T:1945489408 NOTICE: m_deviceType : AE_DEVTYPE_PCM
08:53:21.654 T:1945489408 NOTICE: m_channels : FL,FR
08:53:21.654 T:1945489408 NOTICE: m_sampleRates : 48000
08:53:21.654 T:1945489408 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
08:53:21.654 T:1945489408 NOTICE: m_streamTypes : No passthrough capabilities
08:53:21.654 T:1945489408 NOTICE: Device 3
08:53:21.654 T:1945489408 NOTICE: m_deviceName : Both
08:53:21.654 T:1945489408 NOTICE: m_displayName : HDMI and Analogue
08:53:21.654 T:1945489408 NOTICE: Enumerated ALSA devices:
08:53:21.654 T:1945489408 NOTICE: Device 1
08:53:21.654 T:1945489408 NOTICE: m_deviceName : default
08:53:21.654 T:1945489408 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
08:53:21.654 T:1945489408 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
08:53:21.654 T:1945489408 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
08:53:21.655 T:1945489408 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
08:53:21.655 T:1945489408 NOTICE: m_streamTypes : No passthrough capabilities
08:53:21.655 T:1945489408 NOTICE: Device 2
08:53:21.655 T:1945489408 NOTICE: m_deviceName : pulse
08:53:21.655 T:1945489408 NOTICE: m_displayName : PulseAudio Sound Server
08:53:21.655 T:1945489408 NOTICE: m_displayNameExtra:
08:53:21.655 T:1945489408 NOTICE: m_deviceType : AE_DEVTYPE_PCM
08:53:21.655 T:1945489408 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
08:53:21.655 T:1945489408 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
08:53:21.741 T:1945489408 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
08:53:21.742 T:1945489408 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<busydialogdelayms>750</busydialogdelayms>
</video>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<cache>
<memorysize>31457280</memorysize>
</cache>
</advancedsettings>
08:53:21.743 T:1945489408 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
08:53:21.743 T:1945489408 NOTICE: Default Video Player: VideoPlayer
08:53:21.743 T:1945489408 NOTICE: Default Audio Player: paplayer
08:53:21.743 T:1945489408 NOTICE: Disabled debug logging due to GUI setting. Level 0.
08:53:21.743 T:1945489408 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
08:53:21.743 T:1945489408 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
08:53:21.746 T:1945489408 NOTICE: Loaded playercorefactory configuration
08:53:21.746 T:1945489408 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
08:53:21.747 T:1945489408 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
08:53:22.554 T:1945489408 NOTICE: Running database version Addons27
08:53:35.296 T:1945489408 NOTICE: ADDONS: Using repository repository.xbmc.org
08:53:35.536 T:1945489408 NOTICE: Raspberry PI firmware version: Mar 3 2017 13:42:34
Copyright © 2012 Broadcom
version 9ae30f71c7ef4239e9d5b56346c0842f3ef56736 (clean) (release)
08:53:35.536 T:1945489408 NOTICE: ARM mem: 752MB GPU mem: 256MB MPG2:0 WVC1:0
08:53:35.536 T:1945489408 NOTICE: cache.memorysize: 30MB libass.cache: 0MB
08:53:35.536 T:1945489408 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=250
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
enable_uart=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=87
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=37500
over_voltage_avs_boost=37500
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
08:53:35.537 T:1945489408 NOTICE: Config:
device_tree=-
hdmi_cvt=800 480 60 6 0 0 0
08:53:35.537 T:1945489408 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
08:53:35.539 T:1945489408 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 60.000000 Hz
08:53:35.539 T:1945489408 NOTICE: Found resolution 640 x 480 for display 0 with 640 x 480 @ 59.940063 Hz
08:53:35.539 T:1945489408 NOTICE: Found resolution 800 x 480 for display 0 with 800 x 480 @ 59.000000 Hz
08:53:35.539 T:1945489408 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
08:53:35.539 T:1945489408 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940063 Hz
08:53:35.539 T:1945489408 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
08:53:35.540 T:1945489408 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940063 Hz
08:53:35.540 T:1945489408 NOTICE: Found (
[email protected]) at 18, setting to RES_DESKTOP at 16
08:53:35.540 T:1945489408 NOTICE: Checking resolution 16
08:53:35.871 T:1945489408 NOTICE: GL_VENDOR = Broadcom
08:53:35.872 T:1945489408 NOTICE: GL_RENDERER = VideoCore IV HW
08:53:35.872 T:1945489408 NOTICE: GL_VERSION = OpenGL ES 2.0
08:53:35.872 T:1945489408 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
08:53:35.872 T:1945489408 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
08:53:37.184 T:1807737776 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
08:53:37.224 T:1858069424 NOTICE: Running database version Addons27
08:53:38.687 T:1858069424 ERROR: SQL: [ViewModes6.db] SQL error or missing database
Query: SELECT idVersion FROM version
08:53:38.702 T:1858069424 ERROR: Process error processing job
