Full Version: kodi mythtv channel unavailable
I am using Jarvis and mythtv 0.28. I installed the pvr addon via apt and it somewhat works. By that I mean that random channels will fail to start; the process hangs a bit then times out with a "channel unavailable" message.
The card, Ceton 4, works as I can view all channels using mythforntend. Channels kodi fails to tune will sometimes tune at a later point, so I am puzzled by this.
The "channel unavailable" message is usually due to the channel change taking too long, default 5 seconds.
You can change the default timeout for "Tuning delay (sec)" in pvr.mythtv addon Advanced tab. Suggest you try increasing to 10 seconds.
