2017-04-16, 15:02
I'd like to create a menu item for playing a DVD, but make it only visible if a disc is in the drive.
I looked into skinning guides and found out, that I should use the <visibility condition="System.HasMediadvd"> tag, but I just can't figure out where to put that line.
It doesn't work to put it into IncludesMenuContent.xml or IncludesMenuCustom.xml.
It is also ignored if I change the <setting id="menu1.visible"> tag to System.HasMediadvd in the settings.xml.
Could someone please give me a hint?
