Hi
I have the following problem with my kodi 16.1 jarvis, i had the skin Confluence and i was trying different ones and then by mistake i have install the sky can someone tell me how i do to get back to the original skin Confluence...
Thanks in advance
Dusty Rhodes
depending on the OS you are using go into the
Userdata (wiki) folder and delete the guisettings.xml file.
(2017-04-18, 18:50)bry Wrote: [ -> ]depending on the OS you are using go into the Userdata (wiki) folder and delete the guisettings.xml file.
Hi
My OS is windows 7 and i have enter Userdata and i have delete the guisettings but when i open kodi it is on Skin Sky...
If you can help me i would appreciated
Thank You
Dusty Rhodes
based on a quick google search looks like that stuff is from a banned piracy repo. you should seek support elsewhere as we do not support installations.
only other option is to shift+delete userdata folder.
(2017-04-18, 20:40)bry Wrote: [ -> ]based on a quick google search looks like that stuff is from a banned piracy repo. you should seek support elsewhere as we do not support installations.
Hi
Thanks for your help i got under control the problem was i did not know how on the skin sky where you could change back to the Confluence but i manage to do it..
Thanks again
Dusty Rhodes
