Full Version: advancedsettings.xml for buffer
Hello,
I have a Tvheadend server with 4 Kodi clients. 2 are in local LAN and other 2 clients are in a remote location jo9ined with VPN.
Most of the time the livetv and recordings works well, but sometimes there are freeze in livetv and stream stops in recordings. I think it is related to the network latency, because in the local clients it doesn't happens.
Someone have any configuration with advancedsettings.xml?
I will really appreciate your experience on this.
Kind regards.
I don't think you can tweak any buffering settings for live TV anymore, especially not with pvr.hts. You could try using transcoding profiles for the remote clients to cut down on bandwidth.
(2017-04-22, 14:40)negge Wrote: [ -> ]I don't think you can tweak any buffering settings for live TV anymore, especially not with pvr.hts. You could try using transcoding profiles for the remote clients to cut down on bandwidth.
I need to upgrade my Tvserver hardware to make transcoding, I will try it.
Regards.
