Hi all,
I am trying to make a dynamic list (like recently added movies) with a static item in the last position (like "See all recently added movies"), do any of you know if or how i can create this? Thanks in advance
There's not really any easy way to add a static item directly to the list, but you can fake it by putting a button at the end of the list and then enclose the list and the button inside a grouplist. Though depending on how the list is setup, you might have to get a bit creative with some slide animations.
e.g.
<control type="grouplist">
<orientation>horizontal</orientation>
<control type="list" id="9000">
<onright>9001</onright>
<content>[dynamic content goes here]</content>
</control>
<control type="button" id="9001">
<onleft>9000</onleft>
... [Define button to make it look like its part of the list]
</control>
</control>
From Kodi 18 you can combine static content and dynamic content in a container.
Or you can have more than one dynamic content directory in a single container.
https://github.com/xbmc/xbmc/pull/10730
Wow that is good news! Thx for the update
