Full Version: Info-Button on MCE Remote uses "invisible mouse"
I'm using the VRC-1100 MCE Remote and learned that there have been quite some problems with the "info"-button in the past, because apparently the remote just sends a "right mouse click"-event when this button is pressed.
For me this leads to a quite strange behaviour - whenever I press the info-Button the contextmenu opens (which is good), but not for the currently selected movie but for some other movie which seems to be under some kind of invisible mouse pointer somewhere in the lower half of the screen (e.g. always the one that is second to the right in the lowest row - which makes sense if kodi thinks the remote is some kind of mouse, but is still annoying).
I was wondering if anybody found a way to fix this - I don't use a mouse on this PC, so even disabling the mouse pointer completely would be an option, if it helps with the issue and opens the context menu for the correct movie.
You tried to disable
settings/system/input -> enable mouse and touch screen support
already?
asign the keyboard command to the remote button works for me? MCE remote
