2017-05-07, 10:44
2017-05-18, 07:18
xbmc.getCondVisibility('Window.IsVisible(Home)')
2017-05-18, 11:04
That is python.. I need it in the XML also everyone's skin has a (home) window so how would that be able to tell that the skin is mine?.... I guess the easyest way would be set a property? Onload of my skin ?
2017-05-18, 11:18
Check your skin strings to see if one is already set if not then set one
<onload>Skin.SetString("skin","your skin name here")<\onload>
Then inside your visible tag put Skin.String("skin","your skin name here")
