Full Version: TVDB scraper - Some episodes missing in list (files not recognized)
I have set up a new installation and took care to name all file correctly. About 98% of files were recognized correctly, but a few TV show episodes are missing. An example might be the Czech cartoon O kanafáskovi. The show is online: https://thetvdb.com/?tab=seasonall&id=289276&lid=28 .
The folder contains these files
S01E01_jak_se_potkali_(animovany)_04'_DVBT_CZ_(romin).avi
S01E02_jak_byli_zvedavi_(animovany)_04'_DVBT_CZ_(romin).avi
S01E03_jak_hrali_fotbal_(animovany)_04'_DVBT_CZ_(romin).avi
S01E04_jak_shaneli_panenku_(animovany)_04'_DVBT_CZ_(romin).avi
S01E05_jak_trhali_zub_(animovany)_04'_DVBT_CZ_(romin).avi
S01E06_jak_hledali_brachu_(animovany)_04'_DVBT_CZ_(romin).avi
S01E07_jak_prali_k_narozeninam_(animovany)_04'_DVBT_CZ_(romin).avi
S02E01_jak_leteli_na_pout_(animovany)_04'_DVBT_CZ_(romin).avi
S02E03_jak_chytali_bobra_(animovany)_04'_DVBT_CZ_(romin).avi
S02E04_jak_zavodili_(animovany)_04'_DVBT_CZ_(romin).avi
S02E05_jak_byli_mrnavi_(animovany)_04'_DVBT_CZ_(romin).avi
S02E06_jak_hledali_kocku_(animovany)_04'_DVBT_CZ_(romin).avi
S03E01_jak_sli_do_skoly_(animovany)_04'_DVBT_CZ_(romin).avi
S03E02_jak_leteli_do_nemocnice_(animovany)_11'_DVBT_CZ_(romin).avi
S03E03_jak_spolu_plachtili_(animovany)_11'_DVBT_CZ_(romin).avi
S03E04_jak_nespali_v_knihovne_(animovany)_11'_DVBT_CZ_(romin).avi
S03E05_jak_spolu_skakali_(animovany)_11'_DVBT_CZ_(romin).avi
S03E06_jak_shaneli_darek_(animovany)_11'_DVBT_CZ_(romin).avi
S03E07_jak_hledali_tatinka_(animovany)_11'_DVBT_CZ_(romin).avi
S03E08_jak_zachranili_krecka_(animovany)_11'_DVBT_CZ_(romin).avi
S03E09_jak_jezdili_na_koni_(animovany)_11'_DVBT_CZ_(romin).avi
S03E10_jak_jeli_ve_vlaku_(animovany)_11'_DVBT_CZ_(romin).avi
S03E11_jak_byli_v_divadle_(animovany)_11'_DVBT_CZ_(romin).avi
S03E12_jak_shaneli_pejska_(animovany)_11'_DVBT_CZ_(romin).avi
S03E13_jak_se_spolu_loucili_(animovany)_11'_DVBT_CZ_(romin).avi
The episodes numbering in filenames corresponds to th TVDB exactly. After library update only the first season can be seen in the "TV series" listing. In "files" mode however, all episodes are visible.
What might be wrong? Is there a way to debug / log scraper actions?
Check the language settings for thetvdb. If it is set to "english", it won´t find the shows that have no english version.
To change the language for an specific show, go to videos, press "c" and "change content". In the advanced settings you can change the settings for that show without changing the rest of them.
Thak you, however, this does not help - the scraper is set to cs (Czech) globally
What is the name of the folder where all these files reside?
(2017-05-07, 22:11)Karellen Wrote: [ -> ]What is the name of the folder where all these files reside?
The folder name is "O_kanafaskovi" . This pattern (no national chars and underscores instead of spaces works perfectly for other shows)
I could not replicate your problem.
I set my scraper as follows...
1. Changed Kodi language to Czech
2. Changed scraper to TVDB
3. Changed scraper language to cs
4. Copied and pasted all your episode titles exactly
5. TV Show directory name... O_kanafaskovi
4. Performed an update library
5. All episodes were scraped into the library, except S02E02, but that is because it was not in your list
What happens if you navigate Videos>Files>your source>O_kanafaskovi and manually refresh each unscraped episode?
