Full Version: Button for reboot
Hi to all.
A quick question: there are any button for to reboot KODI system in the app remotre control?
I can´t find this option...
Thank you.
Yes, in the top right there is an icon like an on/off switch. Click it and there are options including reboot.
Oops sorry I am on Tapatalk on my phone and didn't realise you were talking about the iOS remote. My answer relates to Kore.
Thanks nickr.
Yes, with IOS remote I can't find the reboot option, surely exists but I can´t see it... :-(
Don't have an iOS device to test sorry.
On the official iOS Kodi Remote, you have the following options:
Power off System
Hibernate
Suspend
Reboot
Quit
+ a few more.
You can access this menu by pressing the "2 gears" icon in the top right corner of the screen.
It's not on every screen, so you have to navigate to the correct screen.
- go to the Kodi menu (on the iOS) where you can select Music, Movies, TV Shows, Pictures etc.
- At the top of the screen tap the text that tells you which version of Kodi you are using. In my case it says "Kodi v17.1 stable" with a green dot next to it.
- another screen will slide across with the 2 gears icon.
Is this what you were looking for?
