Full Version: Music playback stops (a LibreElec - Bluetooth issue)
Hello all,
I'm new to KODI and to the RPi in general. I don't know what kind of information to post here exactly...
Yesterday I downloaded the LibreElec installer and put the latest version onto a micro SD card. I put that into a Pi 3. It seemed to work without any issues - though admittedly I didn't try very long. I then downloaded the zip file for the estouchy skin and installed it from a network location using the add-on installer in KODI.
Again, everything seemed to be working well. I added my music library, which is located on a NAS, to the library in KODI and started playing music. The problem I'm seeing is that music plays for a few minutes, and then stops playing. The play bar stops moving as well. It doesn't seem to be an issue with the network, because I can still navigate my library. I can go back/forward tracks, and it displays the new track, but will not start playing again.
I am using a bluetooth speaker and the 7" Pi touchscreen as well - both of which connected and worked without issue.
Any advice would be appreciated.
That sounds very odd, what format are the music files that you are playing - mp3, flac, other?
Can you also provide a debu log of playback failing in this way. For more help with obtaining the log from a RPi have a look on the RPi subforum http://forum.kodi.tv/forumdisplay.php?fid=166.
(2017-05-11, 17:32)DaveBlake Wrote: [ -> ]That sounds very odd, what format are the music files that you are playing - mp3, flac, other?
I will post the log file asap. The format is mp3.
So, I was finally able to get back to this and after doing a little more research discovered that the problem is with the Bluetooth drivers in LibreElec:
https://forum.libreelec.tv/thread-1196.html
I am having the same issues as all of these people. Interestingly, it works ok in OpenElec and also if I plug in an analog speaker...
Anyway, I don't think it's a Kodi problem, so thanks!
