Full Version: Fanart Background Change
Hi Gade,
i hope i can make myself clear.
if you add a custom home menu categories you can only choose a bunch of fanarts as background, but NOT only the selected category.
thats quiete a problem if you have kids. (if e.g. a background from horror appears or porn).
maybe you can add "only fanarts from this source" or something.
https://abload.de/img/screenshot00188ugq.png
https://abload.de/img/screenshot002mcubw.png
Hi skybird.
Yeah, I know exactly what you mean.
Only backgrounds provided by script.skin.helper.backgrounds are possible:
https://github.com/marcelveldt/script.sk...the-script
I can't think of a way to achieve what you're after...
hm, i see. only possible way would be a background wallpaper for one smart playlist generated by this script.
thanks a lot for your support.
