Full Version: Indigo emptied out Kodi
A few months back I installed the Indigo Maintenance add-on in Kodi. Kodi almost immediately started failing to perform. I uninstalled Indigo. After upgrading to Krypton, I realized I was still having issues related to the Indigo install. I Unistalled Kodi completely and even tracked down some loose Indigo files and deleted those (Required extra effort due to "Administrative Rights" not being had on a single profile PC). My current issue is that no matter what I attempt to install through the Fusion Repository, the only source under "Install from zip file" is "plugin.program.indigo-1.0.4". I've also noticed that where most people have "start-here", I have a "begin-here" instead. Is this also an after effect of Indigo?
Please advise me in where to go in order to fully wipe Kodi and all possible traces of Indigo. I'd love to just start over I feel defeated at this point.
Indigo Effects...
That's what happens when you install unofficial add-ons... Lots of problems!!!
Thankfully you are only asking for assistance to delete these add-ons, so we can assist you.
I am assuming windows computer here...
1. Uninstall Kodi using the uninstaller
2. Go to c:\Users\Your User Name\AppData\Roaming\
3. Look for the directory Kodi and delete it.
4. Now you can download and install Kodi from here... https://kodi.tv/download
Let us know how you go.
Believe me I regretted the decision immediately.
After Uninstalling Kodi, profile data included, I deleted the Kodi directory within \Roaming. After reinstalling I'm unfortunately still in the same place with my repository :[
Thank you so much though.
Yes, it's one of the worst banned add-ons (wiki) around, in fact it's almost malware.
Was your original install from the MS Store? If so then the kodi folder is in a different place -
[c:]\Users\[user]\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi
where you may need to adjust your install drive (c: in most cases but not always, replace [c:] as appropriate) and of course your user folder in place of [user] in the link above.
(2017-05-16, 04:00)Karellen Wrote: [ -> ]That's what happens when you install unofficial add-ons... Lots of problems!!!
unofficial != dodgy
unofficial !=problems
(2017-05-16, 09:50)DarrenHill Wrote: [ -> ]Yes, it's one of the worst banned add-ons (wiki) around, in fact it's almost malware.
To me it sounds like the OP has already deleted the files & is again trying to install the banned repo, in which case there's probably not much more to suggest here.
Yes, it does read that way. But I am looking at his one and only procedural question...
Quote:Please advise me in where to go in order to fully wipe Kodi and all possible traces of Indigo
