Full Version: Progress bar remove delay after pause or move higher
I have issue with progress bar. After un-pausing it will stay some time and then I can't read subtitles. How can I remove delay or make it transparent or move it up?
http://i.imgur.com/f6RmqFG.jpg
Use fixed for subtitle position, than the progress bar is just at the right height
