Full Version: Working on adding FanArt support to XBMC skinning-engine
Pages: 1 2 3 4 5 6
So we've hashed out a lot of stuff over in the FR thread:
http://xboxmediacenter.com/forum/showthr...083&page=2
And i've started work on the code for Fanart support. Now while I did agree to step up and do this, I certainly wouldn't be averse to help if anyone wants to give it Smile I'm most comfortable with the GUI code in XBMC so that is where i'm starting. If anyone wants to work on how the Fanart images/data will be retrieved/scraped I would be most grateful, but if not then i'll burn that bridge when I cross it.
This is my "todo" list as it were:
  1. Add support for expansion of infolabels in various key tags
  2. Add infolabels for the 6 fanart colors
  3. Add infolabel for fanart image
  4. Perhaps add an .nfo reader for local fanart data, or maybe expand the existing one used for movies. I havent' looked at this at all yet so not positive.
  5. Add some method of scraping fanart data from TVDB and storing that data
The first three items I am most confortable taking care of, and would be most appreciative of any help with the last two.
for local fanart / scraped fanart see CVideoInfoTag::Load() (and Save()). just add another member variable and a suitable xml tag, that tag will be read from nfo files and from the xml returned from the scraper. if you need to store it, find a suitable column (see the enum's and structs in VideoDatabase.h).
spiff Wrote:for local fanart / scraped fanart see CVideoInfoTag::Load() (and Save()). just add another member variable and a suitable xml tag, that tag will be read from nfo files and from the xml returned from the scraper. if you need to store it, find a suitable column (see the enum's and structs in VideoDatabase.h).
Thanks spiff, i'll take a look at that when I get to that point. I appreciate the point in the right direction.
I can help with #5, I'm pretty good at coming up with short algorithms to parse data, show me a couple examples of your expected matches within the haystack, and a couple haystacks, and anything else I need to know.
plex Wrote:I can help with #5, I'm pretty good at coming up with short algorithms to parse data, show me a couple examples of your expected matches within the haystack, and a couple haystacks, and anything else I need to know.
You will need to start by download the latest tvdb.xml as the RegEx XML code for it should be added to it as an option (similar to how IMPAwards and MoviePosterDB are options in imdb.xml, so you want to download that as well to use as an example):
https://xbmc.svn.sourceforge.net/svnroot...ers/video/
Also read up on TheTVDB's API:
http://www.thetvdb.com/wiki/index.php?ti...ammers_API
Then you want to read (and reply if needed) to this topic thread:
http://forums.thetvdb.com/viewtopic.php?p=2777
PS! More about the XBMC's own scraper API can be found in our wiki:
http://wiki.xbmc.org/?title=How_To_Write...o_Scrapers
http://wiki.xbmc.org/?title=Scraper
http://wiki.xbmc.org/?title=Import_-_Exp...eo_Library
http://wiki.xbmc.org/?title=Regular_Expr...9_Tutorial
Happy coding!
Thanks for the help. Don't rush out though because they're still tying up all the loose ends at TVDB so the API probably doesn't include the support for Fanart quite yet. Keep an eye on that thread Gamester17 pointed out at the TVDB forums.
added: initial support for infolabels in <textcolor>, <shadowcolor>, and <disabledcolor> in Label controls.
What's your plan in that regard? It's best to make it as universal as possible IMO.
jmarshall Wrote:What's your plan in that regard? It's best to make it as universal as possible IMO.
I want to. Unfortunately in looking at it, the system really wasn't designed to be universal. Ideally every tag should be able to parse an infolabel, but it looks like it just wasn't set up to allow this. Without a major rewrite I don't see it happening, but you know the code better than I.
Right now i'm just handling required tags on a per-case basis, and expanding the infolabels at render time for the colors. However it isn't done, and i'm having some problems with it so I may step back a few levels and re-think it. Certainly open to suggestions.
How I'd do it is replace all instances of color (there's not that many I think - diffusecolor, and the text/focus/select/shadow colors) with a CColor class, which combines the color with the integer condition. Then you have a Get() routine to request the color. This causes the infomanager to be hit every frame though, but I don't really see any way around that to be honest.
One thing you'll need to watch is that the colors for text are in general passed to the GUITextLayout class (where the text is cached) so you'll need them there as well.
Any ideas you have would be great to know - we can chat via IRC or gchat or whatever if you like - PM me for my gmail info, and let me know when a good time for you is. I'm normally around 8-22 NZ time.
Cheers,
Jonathan
jmarshall Wrote:It's best to make it as universal as possible IMO.
Universal as in it should be able to be used in the music section as well as the videos (TV-Shows) section?
jmarshall Wrote:How I'd do it is replace all instances of color (there's not that many I think - diffusecolor, and the text/focus/select/shadow colors) with a CColor class, which combines the color with the integer condition. Then you have a Get() routine to request the color. This causes the infomanager to be hit every frame though, but I don't really see any way around that to be honest.
Cheers,
Jonathan
That is pretty much how I did it, though I packed the data in a bit tighter, since I didn't want to use up too much memory.
Ok so my original plan was pretty similiar to what you suggested JM, but I was trying to minimize the memory overhead so instead of making a new class to contain the new colors, I was packing things into the existing color variables, with a couple booleans to work as flags.
This wasn't working properly though and as I dug around trying to find what was wrong, I realized I was missing a part of the infolabel parsing.
In hindsight now I think a class like you suggest is a better alternative considering the amount of code needed. Like I said originally I wanted to avoid that new memory overhead, but since it doesn't seem an issue to you that's what i'm going to go ahead and do.
Thanks for the tip!
Rewrote the underlying color code for <textcolor>, <focusedcolor>, <selectedcolor>, <shadowcolor>, and <disabledcolor> to use a new "infolabel aware" class, CGUIInfoColor
The above tags now support infolabels in all controls that use them including:
ButtonControl
ButtonScroller
CheckMarkControl
FadeLabelControl
LabelControl
ListItem
ListLabel
MultiSelect
RSSControl
SettingsSliderControl
SpinControl
TextboxControl
Optimized CGUIInfoColor a bunch
Thanks JMarshall for all your help and support!
Fixed some bugs that broke CGUIInfoColor when I revamped it
BUG: RSSFeedControl isn't displaying colors properly
Pages: 1 2 3 4 5 6
