Full Version: 0.5 apple remote buttons still work for minimized itunes when xbmc is open
when im running xbmc in full screen, the buttons on my remote still work on itunes if its minimized (vs me quitting the itunes), i.e. if i press play forward track rewind etc it simultaneously does specified action in xbmc but also does the same action in itunes. additionally if i press the up down arrow it also does the default change volume for osx even within xbmc (i can hear the popping volume up dwon sound),i don't recall this being a problem with previous versions. do i have to change some sort of settings?
Go into settings, disable and re-enable the apple remote support. There is a bug where the helper looses it's grip on the remote, doing this resets it.
