If you remove the mint theme with sudo apt-get remove xbmc-skin-mint and restart XBMC you will automagically be running another theme (PM3 I think)
I tried the Mint theme and ... I understand the problem now :-) . There is no menu item for settings. So you need to type on "s" (as in system) to get the entries. Then you can select the new theme you want.
S! See, I knew it was somewhere around there.
LOL..
Thanks Guys, I'll try pressing S when I'm in linux next.
After reviewing the packages I think they made a mistake with the facilities of the skins, skins are installed at home (.xbmc / skin) and not in the directory / usr / share / xbmc / skin as they can not read ( at least I do). will have to find another way to install the skins as a package deb can not install a home.
There is two way of installing skins and both can work along.
They can be install in /usr/share/xbmc/skin which is system wide skin and available to every user on the system.
Then, each user can install his own skin in .xbmc/skin and this skin will be available only for him.
I don't understand then why you think this should be changed.
Forgive by translating language, I am not English. I have installed several skins in / usr / share / xbmc / XBMC skin and can only read "Project Mayhem III", where a instalo the skins (.xbmc / skin /...) XBMC if you can read different skins. The installation of skins on (/ usr / share / xbmc / skin) XBMC can not only read other skins (Project Mayhem III).
- can be a problem for permits or configuration XBMC?
so will there be a 64bit version out anytime soon ?. Main reason is iam kinda new to ubuntu running it for 2month now, and i have ben using xbmc sens XBMP was First relesed i dont know howmany years ago that was more then 6 i think anyway i love XBMC and to c Xbmc and Linux join hands almost gives me a hardon. Only thing i dont want to emulate a 32bit due to hazzel etc so iam very ken to know when the 64bit version will be rlsed
geinux : That's indeed strange. How did you install MC360 in /usr/share/xbmc/skin (using the PPA ? or Manual ? )
TrocaNiklas : I don't think there will be an official 64bit version anytime soon. But if you search through the forum you might find some people who succeeded to create a 64bit.
wattazoum Wrote:@geinux : That's indeed strange. How did you install MC360 in /usr/share/xbmc/skin (using the PPA ? or Manual ? )
Install PPA (.deb).
- sudo aptitude install xbmc-skin-*
- Synaptic skin MC360
I just tried what you said you where doing and I get all skins (using the latest SVN PPA) that are under .xbmc/skin + /usr/share/xbmc/skin
sorry for the previous post... I think I figured it out.
I installed the SVN source and now I get more packages.
Do I just need to choose 'xbmc' to install?
