Uuu right. Look like i was using the wrong key.
And synaptic's search is definifly messed up.
Could you guys please tell me if the SVN PPA sourcecode is based on the branch "9.04_Babylon-linux-osx-win32" or the branch "linuxport"? Thank you!
Cheers,
hepi
wattazoum Wrote:Hello,
ADDONS and THIRD PARTIES
Third parties packages will be distributed via a reserved PPA: the xbmc-addons PPA. You will find there skins, scripts and plugins. I suggest you add it to your sources to benefit from all contribution put there.
deb [url=http://ppa.launchpad.net/xbmc-addons/ubuntu]http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu[/url] intrepid main
deb-src [url=http://ppa.launchpad.net/xbmc-addons/ubuntu]http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu[/url] intrepid main
deb [url=http://ppa.launchpad.net/xbmc-addons/ubuntu]http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu[/url] hardy main
deb-src [url=http://ppa.launchpad.net/xbmc-addons/ubuntu]http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu[/url] hardy main
deb [url=http://ppa.launchpad.net/xbmc-addons/ubuntu]http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu[/url] gutsy main
deb-src [url=http://ppa.launchpad.net/xbmc-addons/ubuntu]http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu[/url] gutsy main
Wattazoum
I've got XBMC on juanty, can i use one of the above, or will there be a juanty ppa for addons coming?
Will there be an updated repository for the Addons for Jaunty? The latest repository appears to be Intrepid.
Does there _need_ to be a jaunty version of the addons repository, or should I use the intrepid repos even though I'm using Ubuntu 9.04 and XBMC 9.04 as well?
Pfennig
Intrepid packages would work on Jaunty without issues
wattazoum Wrote:Intrepid packages would work on Jaunty without issues
Cheers, i'll try it on my test machine first
Can someone PM me the key? the port is blocked here at work.
robla64 Wrote:Can someone PM me the key? the port is blocked here at work.
Never mind .... i found the key in the instructions
I use the svn ppa and it hasn't been updated in a while, the latest package seems to be xbmc_9.04~rc1svn19929. Is this the same as the 9.04 babylon release or do I need to use the main ppa for the most up to date xbmc?
Pork - I was thinking the same thing. There is a VDPAU issue that is fixed in a later release...
Its sort of odd, with the lack of updates to the SVN PPA, if you look at the history there usually is never more then a few days between updates. But I suppose its volunteers doing the updating so maybe we shouldn't complain, rather pitch in.
I think the main PPA is still in earlier version yet since the SVN is 9.04 + revision....
Apologies for being such a dump in linux but I'd like to install the linux version as after installed the live version on my computer and installed some addons XMBC is freezing at all times, so I'd like to start a linux installation but I don't know what to do.
Do I have to go to
http://www.ubuntu.com and download the ubuntu? Which 1 the desktop or server version?
Is it possible that someone give me a step by step instructions.
Thanks alot
If you are not familiar to linux i suggest use LIVE version.
queeup Wrote:If you are not familiar to linux i suggest use LIVE version.
How helpful you are. If you read my previous post, I have said that since I have installed some addons the xmbc is freezing and I have to reset it. If someone can guide me, my IQ is not dump though I might getting it working
