any word on getting the svn ppa working again for Karmic and Jaunty?
gets held up here:
cp: cannot stat `/build/buildd/xbmc-9.04.2+svn22583/debian/tmp/usr/share/xbmc/web': No such file or directory
dh_install: cp returned exit code 1
make: *** [install-arch] Error 1
thanks guys
Anyone can start this new xbmc from PPA (SVN:22743) ?
Unable to start SVN22743, I have the first screen xbmc following by a crash ... I don't know what has been changed with this version. For information I use the standard drivers nvdia 180.44.
Waiting for a new version ...
I also cant start SVN22743.
Seems to be a problem with the skins or something like that:
http://pastebin.com/f2498aa8c
http://pastebin.com/f360be2e1
Update:
Ok it seems to work when i change the following in /usr/share/xbmc/skin/PM3.HD/skin.xml:
Quote:<skin>
<defaultresolution>720p</defaultresolution>
<defaultresolutionwide>720p</defaultresolutionwide>
<defaultthemename>textures.xpr</defaultthemename>
<version>3.0</version>
<credits>
<skinname>Project Mayhem 3 HD</skinname>
<name>Coded by Jezz_X</name>
<name>Graphics by Jezz_X</name>
<name>Icons by Mikebeecham (currently)</name>
</credits>
</skin>
Please DO NOT upgrade to r22743, see homepage for why.
althekiller Wrote:Please DO NOT upgrade to r22743, see homepage for why.
Sorry but which homepage ? I can't find this information.
Wow...just...sigh... xbmc.org
althekiller Wrote:Wow...just...sigh... xbmc.org
Ok sorry ...
my problem is that for the moment I am unable to use xbmc on linux, the svn does not work and now I understand why !! , But I don't know how to install easyly another svn.. and with the 9.04 version htsp protocol is not available .. so I need it to whatch tv with tvheadend ..
I suggest you google how to specify the package version to use in synaptic in that case. Why on earth are you using the SVN PPA on a "vital" deployment? You were just asking for this situation.
althekiller Wrote:I suggest you google how to specify the package version to use in synaptic in that case. Why on earth are you using the SVN PPA on a "vital" deployment? You were just asking for this situation.
OK I will finally downgrade to svn 22290 using .deb packages availaible here
http://ppa.launchpad.net/team-xbmc-svn/p...in/x/xbmc/
Regards.
The pre-merge `safe` build r22528 for Jaunty that Wattazoum created last night works fine here - DD/DTS & video playback speed etc are working as expected.
We can all stop playing with Aptitude revision holds and build reversions now.
Thanks Wattazoum
Yes r22528 works when you edit skin.xml and change it to "<version>3.0</version>".
Congrats and thanks for the new build, I let out an audible "yay!" when I saw the new build show up this morning. Works so great so far. Thank you.
MrDVD Wrote:i think inside 22290 dts was defect, better use 22278 this was the last version that was ok. Or move temp to a diff PPA.
https://edge.launchpad.net/~henningpingel/+archive/xbmc
This version work for me and have the pvr inside (you need vdr to use the TV funktion)
Now a new version with experimental pvr-testing is available '22769) .. is this version ok ?
