2009-11-09, 12:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
2009-11-10, 04:27
thanks, you said absoloutely nothing at all.
Raphael Barros's fix works well.
2009-11-10, 16:34
Are packets held back in the PPA because of this?
Maybe Ive been playing around with aptitude too much!
xbmc@htpc:~$ sudo apt-get upgrade -f
Läser paketlistor... Färdig
Bygger beroendeträd
Läser tillståndsinformation... Färdig
Följande paket har hållits tillbaka: (the following packets are held back)
linux-generic linux-image-generic linux-restricted-modules-generic xbmc
xbmc-common xbmc-live xbmc-scripts-example xbmc-skin-pm3 xbmc-skin-pm3-hd
xbmc-standalone xbmc-web-pm3
2009-11-13, 11:20
a little warning: xbmc-live alpha2 package went out without the committed fix for the sudoers file, pls bear with me for being late to fix it
2009-11-13, 11:48
Zapata Wrote:Are packets held back in the PPA because of this?Try
Code:xbmc@htpc:~$ sudo apt-get upgrade -f
Bygger beroendeträd
sudo apt-get distr-upgrade
2009-11-16, 03:03
Hey
Since the alpha1 jaunty update XBMC hasn't been working for me and i've been trying to get the alpha2 installed to hopefully fix the crashing problem.
Initially apt failed to see the alpha2 update at all and now all i get is
i've double checked i have the key installed, other than that i don't really have a clue?
Hit http://security.ubuntu.com jaunty-security/multiverse Packages
Hit http://security.ubuntu.com jaunty-security/multiverse Sources
Fetched 1B in 3s (0B/s)
W: Failed to fetch http://ppa.launchpad.net/team-xbmc/jaunty-ppa/ubuntu/dists/jaunty/main/binary-i386/Packages.bz2 Hash Sum mismatch
E: Some index files failed to download, they have been ignored, or old ones used instead.
2009-11-17, 10:29
Is it correct that alpha2 was pushed to stable?
I have these lines configured in my xbmc.org.list:
deb http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ jaunty main
deb-src http://ppa.launchpad.net/team-xbmc/ppa/ubuntu/ jaunty main
deb http://ppa.launchpad.net/xbmc-addons/ppa/ubuntu/ jaunty main
During my latest apt-get upgrade I noticed this:
Preparing to replace xbmc 9.04.1-jaunty1 (using .../xbmc_9.11~alpha2-jaunty1_i386.deb) ...
Unpacking replacement xbmc ...
Preparing to replace xbmc-web-pm3 9.04.1-jaunty1 (using .../xbmc-web-pm3_9.11~alpha2-jaunty1_i386.deb) ...
Unpacking replacement xbmc-web-pm3 ...
Preparing to replace xbmc-skin-pm3-hd 9.04.1-jaunty1 (using .../xbmc-skin-pm3-hd_9.11~alpha2-jaunty1_i386.deb) ...
Unpacking replacement xbmc-skin-pm3-hd ...
Preparing to replace xbmc-common 9.04.1-jaunty1 (using .../xbmc-common_9.11~alpha2-jaunty1_i386.deb) ...
Unpacking replacement xbmc-common ...
Setting up libass-dev (0.9.6-1ubuntu1~ppa4) ...
Setting up xbmc-common (9.11~alpha2-jaunty1) ...
Setting up xbmc-skin-pm3-hd (9.11~alpha2-jaunty1) ...
Setting up xbmc-web-pm3 (9.11~alpha2-jaunty1) ...
Setting up xbmc (9.11~alpha2-jaunty1) ...
Is this correct?
Is this correct?
2009-11-17, 23:49
kees667 Wrote:I managed to downgrade finally. Collected bits and piece everywhere from the forum and forced an install., I gues probably some steps are not required, but it worked. This is what I did:
Code:pkill xbmc
pkill xorg
sudo apt-get update
sudo apt-get install xbmc
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-skin-pm3-hd_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-web-pm3_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-common_9.04.3+svn22528-jaunty2_i386.deb
wget https://launchpad.net/~team-xbmc-svn/+archive/ppa/+files/xbmc-eventclients-common_9.04.3+svn22528-jaunty2_i386.deb
sudo dpkg -i --force-all xbmc-common_9.04.3+svn22528-jaunty2_i386.deb xbmc_9.04.3+svn22528-jaunty2_i386.deb xbmc-skin-pm3-hd_9.04.3+svn22528-jaunty2_i386.deb xbmc-web-pm3_9.04.3+svn22528-jaunty2_i386.deb xbmc-eventclients-common_9.04.3+svn22528-jaunty2_i386.deb
You can undo the above using the following at the command line
sudo dpkg -i --refuse-all xbmc-common_9.04.3+svn22528-jaunty2_i386.deb xbmc_9.04.3+svn22528-jaunty2_i38
2009-11-18, 01:02
I am having problems running 9.11 Alpha2 on Karmic. It gives me the following error when I try to run it:
This looks to be the same line as in this topic.
Here is the log:
Any insight or suggestions would be appreciated.
~$ xbmc
Xlib: extension "RANDR" missing on display ":0.0".
RandR extension missing
xbmc.bin: ../xbmc/MathUtils.h:33: int MathUtils::round_int(double): Assertion `x > static_cast<double>((-2147483647 - 1) / 2) - 1.0' failed.
/usr/bin/xbmc: line 72: 3332 Aborted (core dumped) /usr/share/xbmc/xbmc.bin "$@"
Crash report available at /home/amee/xbmc_crashlog-20091117_164051.log
Here is the log:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Tue Nov 17 16:40:51 CST 2009
XBMC Options:
Arch: i686
Kernel: Linux 2.6.31-14-generic #48-Ubuntu SMP Fri Oct 16 14:04:26 UTC 2009
Release:
Distributor ID: Ubuntu
Description: Ubuntu 9.10
Release: 9.10
Codename: karmic
############## END SYSTEM INFO ##############
############### STACK TRACE #################
Core was generated by `/usr/share/xbmc/xbmc.bin'.
Program terminated with signal 6, Aborted.
#0 0x00ed4422 in __kernel_vsyscall ()
Thread 1 (Thread 3332):
#1 0x0119d4d1 in raise () from /lib/tls/i686/cmov/libc.so.6
#2 0x011a0932 in abort () from /lib/tls/i686/cmov/libc.so.6
#3 0x01196648 in __assert_fail () from /lib/tls/i686/cmov/libc.so.6
#4 0x0863d1b0 in CGUITextureBase::Render(float, float, float, float, float, float, float, float, float, float) ()
#5 0x0863d6ce in CGUITextureBase::Render() ()
#6 0x0861687b in CGUIImage::Render() ()
#7 0x08274ced in CSplash::Show() ()
#8 0x082d9681 in CApplication::Create(void*) ()
#9 0x084fd44e in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
16:40:51 T:3078842256 M:2931179520 ERROR: Failed to create common scripts symlink.
16:40:51 T:3078842256 M:2931052544 NOTICE: -----------------------------------------------------------------------
16:40:51 T:3078842256 M:2931052544 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Nov 12 2009 (SVN:24548)
16:40:51 T:3078842256 M:2931052544 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
16:40:51 T:3078842256 M:2931052544 NOTICE: special://masterprofile/ is mapped to: /home/amee/.xbmc/userdata
16:40:51 T:3078842256 M:2931052544 NOTICE: special://home/ is mapped to: /home/amee/.xbmc
16:40:51 T:3078842256 M:2931052544 NOTICE: special://temp/ is mapped to: /home/amee/.xbmc/temp
16:40:51 T:3078842256 M:2931052544 NOTICE: The executable running is: /usr/share/xbmc/xbmc.bin
16:40:51 T:3078842256 M:2931052544 NOTICE: Log File is located: /home/amee/.xbmc/temp/xbmc.log
16:40:51 T:3078842256 M:2931052544 ERROR: CXRandR::Query - unable to open xrandr xml
16:40:51 T:3078842256 M:2931052544 NOTICE: Setup SDL
16:40:51 T:3078842256 M:2930417664 ERROR: CXRandR::Query - unable to open xrandr xml
16:40:51 T:3078842256 M:2930417664 INFO: Available videomodes (xrandr):
16:40:51 T:3078842256 M:2930290688 ERROR: CXRandR::Query - unable to open xrandr xml
16:40:51 T:3078842256 M:2930290688 INFO: Number of connected outputs: 0
16:40:51 T:3078842256 M:2930266112 DEBUG: CKeyboardStat::Initialize - XKb symbols pc_us_inet(evdev)
16:40:51 T:3078842256 M:2930266112 INFO: LIRC Initialize: sucessfully started on: /dev/lircd
16:40:51 T:3078842256 M:2930266112 INFO: Drives are mapped
16:40:51 T:3078842256 M:2930266112 NOTICE: load settings...
16:40:51 T:3078842256 M:2930266112 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:40:51 T:3078842256 M:2930266112 NOTICE: loading special://masterprofile/guisettings.xml
16:40:51 T:3078842256 M:2930266112 NOTICE: Getting hardware information now...
16:40:51 T:3078842256 M:2930266112 INFO: Using analog output
16:40:51 T:3078842256 M:2930266112 INFO: AC3 pass through is enabled
16:40:51 T:3078842256 M:2930266112 INFO: DTS pass through is enabled
16:40:51 T:3078842256 M:2930266112 NOTICE: Checking resolution 12
16:40:51 T:3078842256 M:2930266112 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/rtmp/mms/udp
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: flv/aacp/sdp
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdfile
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
16:40:51 T:3078842256 M:2930266112 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
16:40:51 T:3078842256 M:2930266112 NOTICE: Loaded playercorefactory configuration
16:40:51 T:3078842256 M:2930266112 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:40:51 T:3078842256 M:2930266112 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:40:51 T:3078842256 M:2930266112 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
16:40:51 T:3078842256 M:2930266112 NOTICE: Default DVD Player: dvdplayer
16:40:51 T:3078842256 M:2930266112 NOTICE: Default Video Player: dvdplayer
16:40:51 T:3078842256 M:2930266112 NOTICE: Default Audio Player: paplayer
16:40:51 T:3078842256 M:2930266112 NOTICE: special://masterprofile/sources.xml
16:40:51 T:3078842256 M:2923081728 NOTICE: Using fbConfig[0]
16:40:51 T:3078842256 M:2922319872 INFO: GL: Maximum texture width: 8192
16:40:51 T:3078842256 M:2922319872 DEBUG: SECTION:LoadDLL(special://xbmc/system/ImageLib-i486-linux.so)
16:40:51 T:3078842256 M:2922319872 DEBUG: Loading: /usr/share/xbmc/system/ImageLib-i486-linux.so
16:40:51 T:3078842256 M:2922074112 DEBUG: GLX_EXTENSIONS: GLX_EXT_visual_info GLX_EXT_visual_rating GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_control GLX_EXT_texture_from_pixmap GLX_ARB_create_context GLX_ARB_multisample GLX_NV_float_buffer GLX_ARB_fbconfig_float GLX_EXT_framebuffer_sRGB GLX_ARB_get_proc_address
16:40:51 T:3078842256 M:2922074112 NOTICE: GL_VENDOR = NVIDIA Corporation
16:40:51 T:3078842256 M:2922074112 NOTICE: GL_RENDERER = GeForce 9300 / nForce 730i/PCI/SSE2
16:40:51 T:3078842256 M:2922074112 NOTICE: GL_VERSION = 3.0.0 NVIDIA 185.18.36
16:40:51 T:3078842256 M:2922074112 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow ...
!!!!! Truncated to comply with post limit !!!!!!
... GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
16:40:51 T:3078842256 M:2920931328 ERROR: GLX: Same window as before, refreshing context
16:40:51 T:3078842256 M:2920931328 INFO: GL: Maximum texture width: 8192
16:40:51 T:3078842256 M:2920931328 INFO: load language info file: special://xbmc/language/English/langinfo.xml
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
2009-11-18, 03:27
I am trying to run 9.11 Alpha 2 on Ubuntu Karmic (32bit) and it is crashing on startup.
NVIDIA GeForce 9300 / Core2 (Wolfdale)
Any help would be great.
Crash log.
Crash log.
2009-11-23, 17:46
Notice to all:
Current Karmic Beta 1 PPA build r24896 on both SVN and regular PPA are missing the VDPAU support.
2009-11-23, 20:12
Qroach Wrote:Notice to all:
I am looking into this. It can be due to the version of the driver it has been built against ... If it's the case, I will make a second build solving the issue.
2009-11-23, 21:30
Awesome, thanks for the quick response!
2009-11-24, 16:17
the build version of Beta1
rUnknown
Seems that the jaunty-ppa repo's build is not correctly version-ed. is this a concern? maybe something to do with this diff?
rUnknown
only in patch2:
unchanged:
--- xbmc-9.11~beta1.orig/debian/svnrevision
+++ xbmc-9.11~beta1/debian/svnrevision
@@ -0,0 +1 @@
2009-11-24, 19:16
vajonam Wrote:the build version of Beta1
rUnknown
It's not a concern :-) the important information is the TAG on this one.
