2010-08-18, 10:37
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
2010-08-18, 10:45
Has anyone managed to update to the latest svn?
I can see xbmc has been built, but running apt-get update shows no updates available for xbmc
2010-08-18, 11:00
tdw197 Wrote:Has anyone managed to update to the latest svn?
What does "apt-cache policy xbmc" say for you? I just found out the version I have installed is 10.0~..., and the one in the ppa is 10.08~... (as it should be). So you need to force the install of the new version. Maybe a ppa-purge followed by re-adding the ppa?
2010-08-18, 11:03
if your installed xbmc version is 2:10.08whatever it wont upgrade to the one on ppa since its 1:10.08whatever, ceros was compiling with epoch 2 and TheUni is using 1 which is really bad again only to mess up whats already been done. please moan to TheUni he dont listen to me.
2010-08-18, 11:06
ah thanks, you are right:
I've never done a ppa-purge, how is it done?
Edit - never mind, its fairly easy (google is my friend )
Quote:Installed: 2:10.0~svn32696~deb1-1~0karmic2
Candidate: 2:10.0~svn32696~deb1-1~0karmic2
Version table:
*** 2:10.0~svn32696~deb1-1~0karmic2 0
100 /var/lib/dpkg/status
1:10.08~svn32869-karmic1 0
500 http://ppa.launchpad.net karmic/main Packages
1:9.11+svn30178-karmic1 0
500 http://xbmcfreak.binkey.nl karmic/main Package
2010-08-18, 11:10
tdw197 Wrote:ah thanks, you are right:
What I did:
sudo ppa-purge ppa:team-xbmc-svn/ppa
sudo add-apt-repository ppa:team-xbmc-svn/ppa
sudo apt-get update
sudo aptitude safe-upgrade
Edit: No, it didn't. Extra steps (since some files are now in different packages than they were in 9.11):
sudo dpkg -i --force-all /var/cache/apt/archives/xbmc-skin-confluence_1%3a10.08~svn32869-lucid1_all.deb
sudo dpkg -i --force-all /var/cache/apt/archives/xbmc-data_1%3a10.08~svn32869-lucid1_all.deb
sudo aptitude-safe-upgrade
This finally got me a updated xbmc.
2010-08-18, 11:15
jbernardo Wrote:What I did:
This should work...Code:sudo ppa-purge ppa:team-xbmc-svn/ppa
sudo apt-get update
yes, but as i'm running xbmc live i had to install ppa-purge first.
to anyone else who may need this, for karmic, i ran the following before the above:
wget http://ppa.launchpad.net/xorg-edgers/ppa/ubuntu/pool/main/p/ppa-purge/ppa-purge_0.2.6~karmic_all.deb
2010-08-18, 11:30
Further to the above aptitude safe-upgrade didn't work for me, but apt-get dist-upgrade did
2010-08-18, 14:18
'aptitude safe-upgrade' nor 'apt-get dist-upgrade' did the trick for me after ppa-purge:
Any ideas?
Quote: Installed: 2:10.0~svn32789~deb1-1~0karmic1
Candidate: 2:10.0~svn32789~deb1-1~0karmic1
Version table:
*** 2:10.0~svn32789~deb1-1~0karmic1 0
Any ideas?
2010-08-18, 14:59
yes, purge the installed xbmc and install the new one. Also go moan to TheUni, I been trying to tell him about this since yesterday but i get ignored.
FYI ppa-purge is NOT gonna make a difference.
2010-08-18, 15:06
release 'lucid' for 'xbmc' was not found
wtf?!
wtf?!
2010-08-18, 15:54
X3lectric Wrote:yes, purge the installed xbmc and install the new one. Also go moan to TheUni, I been trying to tell him about this since yesterday but i get ignored.
So if I do a sudo apt-get purge xbmc then an install of xbmc I will get the latest version?
2010-08-18, 16:01
Thanks fo X3electrick for providing a build to download. I initially compiled one but it was too unstable. I compleltely removed it using Synaptic Package manager and installed the build from team-iquick.
Is it normal that the scraping does not work for this build? Also, it is normal that there is a crash log when it exits?
2010-08-18, 16:28
@ poserdognut
This are the package names that you will need to install (if you need all of them is up to your needs and setup e.g. full desktop/gnome/kde or XBMCLive or from script minimal install karmic + xci of course.
so type apt-get install xbmc xbmc-bin etc-etc -y
@ plum7500
the issue with scraper is a bug which has been fixed on svn already
once I get a newer svn on ppa it should have this fixed.
I was trying to do own self ppa builds but only got x86 compiled ok x64 failed to build...
I will try again later today though this is not gonna be on same ppa Im using for XCI, This is safest way to do it...
[b]xbmc[/b] XBMC Media Center (full metapackage)
[b]xbmc-bin[/b] XBMC Media Center (binary data package)
[b]xbmc-data[/b] XBMC Media Center (arch-independent data package)
[b]xbmc-dbg[/b] XBMC Media Center (debug package)
[b]xbmc-eventclients-common[/b] XBMC Media Center (Event Client Common package)
[b]xbmc-eventclients-dev[/b] XBMC Media Center (Event Client Dev package)[b]
xbmc-eventclients-j2me[/b] XBMC Media Center (Event Client J2ME package)[b]
xbmc-eventclients-ps3[/b] XBMC Media Center (Event Client PS3 package)[b]
xbmc-eventclients-wiiremote[/b] XBMC Media Center (Event Client WII Remote support package)[b]
xbmc-eventclients-xbmc-send[/b] XBMC Media Center (Event Client XBMC-SEND package)[b]
xbmc-live[/b] XBMC Media Center (XBMC Live package)[b]
xbmc-skin-confluence[/b] XBMC Media Center (Confluence skin)
[b]xbmc-standalone[/b] XBMC Media Center (standalone program)[b]
xbmc-web[/b] XBMC Media Center (POC web frontend)
2010-08-18, 16:44
@X3lectric: Not at all related to the themoviedb.org changes from today. Something else is wrong.
@plum7500: Don't threadjack, please create a separat thread for your issue.
