Quote:
[Apple Movie Trailers II Plugin]
- added: initial commit
* XBMC revision 13322 or newer to take advantage of Theater Showtimes and Download Trailer feature
This plugin only lists the 60 or so most current trailers. No need to create a database. Quality can be standard, 480p or 720p. any info on finding the 1080p would be appreciated.
Two features accessed from the context menu (a new feature in XBMC as of revision 13322) are Theater Showtimes and Download Trailer.
As always access the plugin settings to set your preferences. You may save to a samba share.
Should support all platforms, xbox, windows, linux and osx. any osx users could post here if it doesn't work for you, i don't have a mac.
The theater showtimes is a window currently until we can fix a bug in XBMC. Then I will change it to a dialog.
You can find it at
http://xbmc-addons.googlecode.com/svn/tr...ilers%20II
or install it from the addons plugin installer, link in the sticky.
Edit: Do not use a mouse when selecting download trailer, if you do the selection can change and you'll end up dowloading a different trailer. I'm trying to resolve this.
nice work, I'll be updating this in my box...thanks bro!
Thank you for this release. How do i set the plugin to do 720p
Quote:
[Apple Movie Trailers II]
- added: 1080p support (experimental, but the few i tried work)
if anybody uses this and finds any 1080p trailers that don't work, let me know
- changed: version -> 1.5
- changed: english language strings
- changed: now uses play mode, stream, download, download & save
- added: settings for adding -trailer to saved filename and always play saved trailers
- changed: context menu, only shows plugins items
you need a current xbmc version
Hmm... I can't get this plugin to work. I tried installing it my self and with the SVNRepoInstaller. Here is the error I found in my log.
http://pastebin.com/d33d7e2d7
This is in linux, and other plugins work fine.
how old is your build? you need to update for a new feature. otherwise grab the tagged one 1.4.2 i think.
Quote:
NOTICE: ERROR: _Parser::_add_video (148) - addContextMenuItems() takes no keyword arguments
I'm sorry, I think I missed a step. Do I have to run 'BUILD.BAT' before i use it? Is there a build.sh?
no you don't have to but yes it does and yes you can.
build.sh gets rid oif the .svn folders
Thanks I have just registered though have been reading this forum for a while
Guys, I can't figure out how to change the plugin settings- can someone give me a noob article on how to do this?
go to the plugin in videos > video plugins> then either right click or hit the c key to bring up teh additional menu.
