Full Version: Remotexbmc1.5 - Stable Version For Xbmc
Pages: 1 2 3
RemoteXBMC News version Stable 1.5
Remote control for xbmcpc : REMOTE XBMC 1.5 drivers include + news Keymap.xml.
For the original remote control xbox change USB + xbmc pc rev 13239 or 12882. version 1.5
- Connect your ir in USB
- install the drivers and restart
- insert the keymap.xml in the folder USERDATA and run the REMOTE XBMC 1.5
Please send me your comment.
thank all for your help.
the XBOX-Remote "Title" and "Back" button doesn´t work.
Here is a link:
http://upload.wikimedia.org/wikipedia/co...kspace.svg
The button with the red circle is the "Back" button for the Remote and the purple button is the "Title" button.
Ok BACK button is corrected, Touch 5 for MUTE but I can not find the key code for TITLE! Huh
mode2006 Wrote:... I can not find the key code for TITLE! Huh
EvebtGhost call it "Apps".
ok! the BACK work now ?
NoEek
LOL if you play an SOUND MUTE (5) works?
mode2006 Wrote:LOL if you play an SOUND MUTE (5) works?
How do you mean that?
Key 9 is Mute, sorry for my english.
hmm the version 1.5 + keymap included back button work and 5 mute work too.I do not understand Huh
9 Mute Ok
I had used a programmed Universal Remote, now with the Original XBOX Remote "Back" works.
the keymap with your package should be:
<FullscreenVideo>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <backspace>SmallStepBack</backspace>
      <return>AspectRatio</return>
      <escape>OSD</escape>
      <menu>CodecInfo</menu>
      <i>Info</i>
      <t>CodecInfo</t>
      <left>StepBack</left>
      <right>StepForward</right>
      <up>BigStepForward</up>
      <down>BigStepBack</down>
    </keyboard>
  </FullscreenVideo>
then, title and info works as xbmc for xbox for me.
alleluia !! thank ultramagnus Nod
thonton remotexbmc 1.5 work for you ?
Pages: 1 2 3
