I wasn't happy with the default Yahoo search engine for getting box art for my video games, so I made two search engines that use
GiantBomb's
API.
GiantBomb_v1 is the first one I made. It gets the first images that are returned when you do a normal game search, but it's not always accurate for games that have many releases or sequels.
GiantBomb_v2 digs much deeper to get as much box art as it can, but is much slower because it crawls through more data.
For example, with v1, "Mortal Kombat" returns various Mortal Kombat images and screenshots, but not the SNES box art that I wanted.
On v2, "Mortal Kombat" returns every box art for almost every Mortal Kombat game, including the SNES box art. But because there's so many games, it takes longer to get the results.
So I included both versions in this zip file. I recommend using v1 most of the time, but switching to v2 when v1 fails.
Download:
http://samutz.com/xbmc/launcher_giantbomb.zip
Both folders go in <launcher path>/resources/search_engines/
Tested on XBMC 9.11 using
JustSomeUser's r1 patch, running on Windows 7 Home x64.
Also worth noting that when you use the "Get Thumb" feature, it includes the launcher name in the search query at first ("Mortal Kombat Super NES" for example), which won't always return results. When it asks you modify your query, just erase the laucher name and try again.
Or you can fix this yourself by editing <launcher path>/resources/lib/launcher_plugin.py and replacing this
search_string = "%s %s" % (romname, launcherName)
with this
search_string = "%s" % (romname)
(in the _search_thumb function)
