Hi
does anybody know what is the "container" in the list of media-sources?
i cant open/edit/delete it...
do i need it? if not how can i remove it?
Hmm, not sure what you are referring to. Mind elaborating with a screenshot or something?
i mean this "container", above the "FILME"-entry:
it looks like you added that, possibly by accident. post the video section of sources.xml.
there is no entry about container:
<sources>
<programs>
<default></default>
</programs>
<video>
<default></default>
<source>
<name>FILME</name>
<path>smb://xxxxx:zzzzz@SERVER/FILME/</path>
</source>
</video>
<music>
<default></default>
</music>
<pictures>
<default></default>
</pictures>
<files>
<default></default>
</files>
</sources>
its not a defined source alright. do you have a usb flash drive connected to your system by any chance? it may have been auto mounted.
oops...
i forgot to say:
its a "XBMC LiveUSB" version
but thats it? you dont have another flash device attached? enable debug logging and try to access it. post the log to pastebin and post a link here. it may yield some clues about what it is. right now, im stumped.
do you know where are the logs stored?
The logs should be in /var/tmp
that log snippet is useless. try the entire log.
