Full Version: Problems with XBMC in fullscreen mode
Hi.
I'm sorry if this has been posted somewhere before (and i would appreciate the link if it has), but i have searched everywhere and can't find the answer to what i hope is a simple problem.
So the problem is this:
When i start XBMC in fullscreen mode it does not actually take up the full space of the screen.
It sits in the bottom left-hand corner.
I'm sorry, but i am really bad at explaining the problem, and i don't have any pictures for illustrative purposes.
I am running it under Windows XP home. My computer's native and maximum resolution is 1280 x 800. Currently i have all the default video settings set to the default/auto settings.
Basically, i want to know how i can enable it to take up the full screen.
Thanks in advance for any help or suggestions.
Regards,
Ethan
Try Settings->Appearance->Screen, and adjust to 1280x800 (Desktop).
And also check under Settings - video - video player (think thats it) for the resolution of the video player portion itself. Make sure it is the (fullscreen) resolution or you will encounter funny things.
