hello everybody
first of all i would like to thank the xbmc team... i really dont know what would be of my life without it...
i've upgraded to the new beta 1 atlantis version, and now i started to use the movie fanart function... very nice, in the new PM3.HD... but i do have a question
if i have a file like this:
300.avi
i use this pattern:
300.tbn (cover)
but whats the filename to the fanart jpeg when i'd have a movie with 2 cds?
i'm using like this:
Casino Royale.cd1.avi
Casino Royale.cd1.tbn
Casino Royale.cd2.avi
i've tried this:
but without success... someone know whats the correct filename to the fanart image?
thank you all, i just love xbmc
*sorry for my bad english though*
febox-pootz Wrote:but whats the filename to the fanart jpeg when i'd have a movie with 2 cds?
i've tried this:
"Casino Royale-fanart.jpg" will work here as it`s handled in the same manner as normal thumbnails.
Any manual added thumbnail or fanart will have to be named like the stacked filename. Please make sure to use the library mode for testing and report back.
thanks man that worked, i dont know what i've done wrong before... really appreciated
I'm usually dead wrong when ever submit a post, but:
I'm using Media Companion.
Say I have 2 stacked AVIs in a "Movie" folder that are named
movie.cd1.avi
movie.cd2.avi
The resulting nfo and tbn files from Media Companion are
movie.cd1.nfo
movie.cd1.tbn
XBMC has no issues finding these files and using the info therein.
This is in keeping with the above mentioned naming conventions yet XBMC doesn't see it until I name it to what you are stating here, namely
I guess my question is why the change in naming conventions?
It seems this would make it more difficult for apps like Media Companion since it has to strip out part of the filename.
Again, I apologize if I'm confused or missing something.
Any help would be appreciated.
You nfo and tbn should be using the stackname as well. You probably scanned with "Use Folder Names for Lookup" which will just grab the first nfo and tbn it finds.
althekiller Wrote:You probably scanned with "Use Folder Names for Lookup" which will just grab the first nfo and tbn it finds.
It would be great if it grabbed the first image file with "fanart" in the file name as well when this option is checked.
It would simplify fanart naming issues greatly.
the intention is that fanart.jpg should work in these cases.
however by looking at the code seems i forgot about it
Thanks for the info.
So will the addition of this capability be blocked because of the feature freeze?
Or am I wrong in assuming you are still planning on adding it?
nuzecast Wrote:Thanks for the info.
I think its a bug, so it should be fixed, i hope.
as i also have multipart movies & its not working:
Alexander CD1.avi
Alexander CD2.avi
"Alexander CD1.avi" + "Alexander CD2.avi" will get stacked to "Alexander.avi". Fanart has to be named: "Alexander-fanart.jpg".
The wiki needs to be updated to reflect this :-
http://wiki.xbmc.org/?title=Thumbnails
States :-
Multi Part (Stacked) Movie Files
You can either use the filename of the first file in the stack or the name of the stack, so for:
Movies\path\moviename-CD1.avi
Movies\path\moviename-CD2.avi
Either of the below would work:
Movies\path\moviename-CD1.tbn
Movies\path\moviename.tbn
Which is clearly incorrect.
billyad2000 Wrote:The wiki needs to be updated to reflect this :-
Nope, it's correct. This is exactly the way local thumbnails are handled on stacked movies.
Unfortunately local fanart images are not handled this way, so you will have to use the "stacked" moviename instead.
Please submit a new feature request, otherwise it might get lost during the current feature freeze.
