Would it be a bad idea to add "Home" and "Back" buttons (icons) to each screen/section?
I think that having such buttons it would make mouse navigation more obvious, and it would enable simpler touchscreen and one-button (Mac) mouse action to go back one step or go to the home screen.
PS! Maybe disable/hide those buttons if the user disable the mouse under settings?
....or even have a separate setting for disabling/hiding the "Home" and "Back" buttons.
I think it would be a welcome addition, not just for mouse users, but also for anyone who uses a remote. It's not a big deal for me to navigate around, but I hate trying to explain to the wife why she has to keep hitting exit on the remote to get back to the home screen.
I've been messing with the keymap.xml and the commands alot lately and I think that GUI buttons are the way to go.
Would have to be carefully thought out though as it shouldn't detract from usability. We spent a lot of time trying to come up with a simple and clean way of navigating within screens and between screens.
Quote:I think it would be a welcome addition, not just for mouse users, but also for anyone who uses a remote.
Agreed! XBMC in general & mediastream specifically is pretty intuitive as it is, but sometimes I still have to explain to people how to go back with the remote or controller (idk how they miss the 'Back' button, but whatever, GUI buttons would probably be more obvious to newbies)...
I would actually like to see a "Home" button and a "Back" button in the GUI of all skins, not just MediaStream
...but it got to start somewhere with one skin and I thought be best to discuss the idea for MediaStream first
May I suggest that "Home" button icon is designed as a small 'house' and "Back" button as a left-pointing-arrow.
I like this idea, 1+ from me.
I'd like the back button to be mappable to a remote as well...
rwparris2 Wrote:Um...
http://wiki.xbmc.org/?title=Keymap.xml
Yea.. I've researched this for a while and the problem is that there isn't one but many back buttons: parentdir, previousmenu, stop, tab, arrow left (in media stream). The closest "back" button is Esc, but in some cases Esc just goes to home it doesn't go back.
Can´t you put a invisible button at the top left corner with back funktion?
Maybe only invisble when it is disturbing the layout? I´m planning to use this skin with a 15" touch screen..
Regards
Henric
At last i found a forum, thats talk about touch screen, i have 3 touchscreens for test, and i have triede some software but i mist the back buttom, on all the programs, so if there some skin i can use or some one can tell have to change a skin i will bee wery happy...
Mads Nielsen
Anyone hvae triede mediaportal software?
+1 as i think it would make my carpc better lol
