Full Version: Get context Menu on appletv and Apple remote
hi
I searched the forums but could not Find a way to Open the context menu on a library source via the apple remote on appletv
Alex
alexioklini Wrote:hi
Alex
I'm not sure there is a why unless a custom keymap is used. If you have an Intel OSX box, here is a link to a command-line app that can send keyboard commands to the AppleTV
http://code.google.com/p/atv-xbmc-launch...bmc_remote
It's a remote EventClient so that has to be enabled in the XBMC on the AppleTV.
param syntax is
./xbmc_remote <IP of the AppleTV> 9777
davilla Wrote:I'm not sure there is a why unless a custom keymap is used. If you have an Intel OSX box, here is a link to a command-line app that can send keyboard commands to the AppleTV
param syntax is
Can you please elaborate on how to do this for someone completely stupid? I've got XBMC on my AppleTV, but I can't use the scraper cause I can't access the contextual menu, which kind of makes it very "unpretty". I need help figuring out how to get to the contextual menu.
lboyce Wrote:Can you please elaborate on how to do this for someone completely stupid? I've got XBMC on my AppleTV, but I can't use the scraper cause I can't access the contextual menu, which kind of makes it very "unpretty". I need help figuring out how to get to the contextual menu.
You need another computer running OSX Intel. That's the host computer. xbmc_remote is a command-line app it runs on the this computer. Run it in the terminal window.
Find the IP of your AppleTV. Use the IR remote to enabled a remote event client (network -> something ->remote events) can't remember the fill path to it
That enabled XBMC to listen for remote events coming from external computers.
./xbmc_remote <IP of you appleTV> 9777
then start typing. Your keyboard hits now will do to XBMC on the AppleTV.
davilla Wrote:You need another computer running OSX Intel. That's the host computer. xbmc_remote is a command-line app it runs on the this computer. Run it in the terminal window.
Thank you so much!!
Don't mean to be a pest, but can you possibly explain how you run xbmc_remote in terminal? I'm not familiar very much with terminal and all I see is a file in that link
lboyce Wrote:Don't mean to be a pest, but can you possibly explain how you run xbmc_remote in terminal? I'm not familiar very much with terminal and all I see is a file in that link
see http://forum.xbmc.org/showthread.php?p=2...post224496
and
http://forum.xbmc.org/showthread.php?p=2...post223941
Got it. I was making that way harder than it was.
Hi davilla,
Thanks for responding.
One more question:
Is it planned for an upcoming release to have context menu automatically mapped to some button ( e.g. menu hold ) ?
If not, can you direct me on how to change the key mapping myself for the beta 1 ?
Thanks,
Alex
alexioklini Wrote:Hi davilla,
One more question:
Thanks,
Alex
Well, I am trying exactly the same thing. Here are the relevant links that should help to get it done. Unfortunately, I havent succeeded yet. Please keep me posted if you do and how you did it...
Description of the file that includes the keymaps
http://wiki.xbmc.org/?title=Keymap.xml
Description of the Apple Remote Keymaps
http://forum.xbmc.org/showthread.php?tid=33056
Hi steve1977,
I will try later today when i am at home and have access to my apple tv.
Of course i keep you informed about my findings.
Regards,
Alex
I'm surprised no one has created a simple Mac OSX-based remote app or even a web U/I or Flash app to do this yet without the need for command-line crap...which is a very unfriendly way to do it.
Even though I have an Intel OSX box, I prefer to use the iPod/iPhone app or the Android App on my phone, which IMHO is superior.
Confused here...why not just hold down the menu button to get the menu for "set content" scrapers etc? Is it more complex than that? I'm on ATV with ATV OS and it works fine in XBMC to do it this way.
I don't get it neither.
I have a Mac Mini and Apple Remote with XBMC worked out of the box
