Full Version: Picture view crashes with Atlantis final
Today I updated Xbmc from beta2 to final using the ppa.
I noticed that when trying to view my photos, which are shown using the picture-view, xbmc crashed instantly.
So I had to change the skin to pm3.hd, change the view, then change back to mediastream and use the list view. Then if I changed the view to pictures again, it crashed.
So I figured this might be something skin-specific, cause it works with all views in pm3.hd. Also the other views work in mediastream.
EDIT: I also had this crash using the pm3.hd-skin now, so I guess I was wrong in thinking this was skin-specific. So feel free to move this thread to a more suitible location, thanks!
Log: http://pastebin.com/m1d8da5f6
It have worked fine previously with both beta1 and beta2.
r16148/9 contains a fix for the largeimage control that *might* be the cause. Does it segfault at all? Your log file doesn't indicate that there was a problem from XBMC's perspective, but it may be either internal to SDL or GL.
Thanks for your answer!
Yes, it says "Segmentation fault (core dumped)" when I run from a terminal.
Let me know if there's anything I can do/try that helps!
See the sticky in the linux forum on how to get a stack trace and so on.
Cheers,
Jonathan
Here's the backtrace: http://pastebin.com/m71dcedb4
I hope that's what you meant.
FYI: just tried 8.10final1-svn16188 and there it seems to work again. Thanks!
Has there been any development on this problem? I just upgraded from the beta to the final and now I can't view images using the Pictures interface (same crashing behaviour).
I'm about to show some pics to my family and would like to do it through XBMC -- is there a quick way to revert to the beta just to I can do this?
yellowman Wrote:FYI: just tried 8.10final1-svn16188 and there it seems to work again. Thanks!
How did you revert? I don't want to lose all my library data!
PS I'm using 8.10final1-hardy4.
Confirmed. Crash problem is fixed in 8.10final1-svn16188.
@melat0nin :
Add the Daily build PPA's to your /etc/apt/sources.list
do a :
apt-get update
apt-get install xbmc
You should now have installed the xvn16188 build
See also :
http://forum.xbmc.org/showthread.php?tid=33327
