Full Version: [RELEASE] G4TV (Video) Plugin
Pages: 1 2 3 4 5
Downloads & Updates are available via XBMC Addons Manager
Post any questions or comments here. Wink
Thanks for all your work.
Nice one thanks. I usually use Navi X for my G4 fix, but this is way better.Big Grin
Excellent job! Everything works great man Smile. Can a download option be added?
XBMCG33K Wrote:Excellent job! Everything works great man Smile. Can a download option be added?
There is a download option Big Grin, it's in the plugin settings menu.
Damn didn't look sorry, bout' that.
Very nice content!
Thanks a lot!
The podcasts are no longer working. I'm on an xbox using the jan 25, 2009 build and this was working a few days ago. The TV Shows section appears to be intact.
I'm getting the error:
sys:1: DeprecationWarning: Non-ASCII character '\xe2' in file Q:\plugins\video\G4TV\default.py on line 150, but no encoding declared; see http://www.python.org/peps/pep-0263.html for details
here's the full xbmc.log file: http://pastebin.ca/1332355
nicoli_k Wrote:The podcasts are no longer working. I'm on an xbox using the jan 25, 2009 build and this was working a few days ago. The TV Shows section appears to be intact.
Thanks for notifying me.
[Update]
-fixed: the G4 Podcast directory wasn't listing videos
I found that the newest xbox build from march 3rd is having issues playing Around the Net without resorting to buffering a lot. I'm able to watch an entire episode using the January 25 build with no buffering.
Here's the march 3 build's debug: http://pastebin.ca/1353278
Here's the jan 25 build's debug: http://pastebin.ca/1353279
I exited both of them prematurely at around the same time in the podcast. I tried several times using the march build just to make sure that it wasn't a random occurrence and it was replicated every time.
I'm not sure if it's a problem with the xbmc build, the plugin, or how they're interacting with each other but I wanted to give you a heads up that there's something going on with it. I haven't run into any other errors with the most recent t3ch build though, so hopefully it's an easy fix.
I've been using this plugin for some time now but never noticed the thread. So , just a quick thank you for making this, I use it all the time Smile
Jeroen Wrote:I've been using this plugin for some time now but never noticed the thread. So , just a quick thank you for making this, I use it all the time Smile
Thanks Wink
I'm having the exact same constant bufferring symptoms previously mentioned here:
nicoli_k Wrote:I found that the newest xbox build from march 3rd is having issues playing Around the Net without resorting to buffering a lot. I'm able to watch an entire episode using the January 25 build with no buffering.
If it makes a difference, my Xbox is softmodded with the T3ch 03-04-09 SVN release of XBMC.
Also, as a side-note/request, any hope of adding the Ninja Warriors streams to this plugin?
Wii's and PS3's get a decent page by and maintained by G4TV:
Wii: http://g4tv.com/wii/index.html
PS3: http://g4tv.com/ps3/index.html
(Sorry if this looks like too much scope creep!)
-JB
Since the plug-in works flawlessly with the january 25 build, I think that the problem is with the 3-04-09 T3CH build. In the channelsurfing.net thread Waffa pointed me towards a thread showing the problems with the build including memory issues.
Waffa Wrote:Script is probaly not broken, march 4 t3ch has problems. And also the february build got that problem.
See this tread.http://forum.xbmc.org/showthread.php?tid=46490
I always maintain the last working t3ch along with the newest t3ch build. I'm currently using the 1-25 build as my main build and I have the 3-4 build as my second build to run the programs requiring the special:// format.
thanks again stacked. I use this on at least an every-other-day basis.
jbagnulo Wrote:Also, as a side-note/request, any hope of adding the Ninja Warriors streams to this plugin?
There is a Ninja Warriors video podcast under "G4 Podcasts"
Pages: 1 2 3 4 5
