Full Version: Load XBMC with IRSS.
I'm using IRSS to load XBMC from my Windows XP desktop with my MCE remote. I've done it like described here on the forum, so translator is using "the green button" combined with the run command:
Quote:Description: Start XBMC
Application: C:\Program Files\XBMC\XBMC.exe
Start Folder: C:\Program Files\XBMC\
Parameters: -fs -p
Window Style: Normal
All other options unchecked
- When done, press set.
- Minimize "Translator" and press the button you chose to launch XBMC.
It workes like a charm first time. But afterwards XBMC starts, but get inactivated by something, so it "goes to the background". So i can see the taskbar and XBMC is flashing down there. Now i have to grab my mouse (dinovo mini) to click it active again.
Has anyone had the same problem, and maybe even a solution for me?
What build are you using?
The final 8.10 version, with no extra builds installed!?
IRSS v. Test Build 1.4.2.2391
Try using one of the third-party builds in the sticky at the top of the page.
