Full Version: .nfo fields
Simple question:
Which fields does XBMC currently read from an external .nfo file? And what are the supported field names?
Anyone has a link to information on this?
Quickest way to check what's currently supported is to simply export your lib to xml and have a look. Otherwise you'd have to rely on the developer who added/removed a field to change the wiki...
sho Wrote:And the Wiki part is here:
http://wiki.xbmc.org/?title=Import_-_Export_Library
Thanks, just what i needed to make a fully compatible xml Smile
