Full Version: Some shows not playing from Library (AppleTV)
When in the TV SHOWS portion of the library, some shows won't play when I click on them. They will play from the VIDEO section, but not in TV SHOWS.
This doesn't happen to all series, just some.
This is on an apple tv.
A debug log would be helpful in this situation. Go into the System Settings and turn it on and then paste it on a pastebin site.
Can do.
Where does the debug log get saved to?
It varies dependant on platform. Checkout the wiki for more info:
http://wiki.xbmc.org/?title=HOW-TO_Submi..._debug_log
Plan9 Wrote:When in the TV SHOWS portion of the library, some shows won't play when I click on them. They will play from the VIDEO section, but not in TV SHOWS.
Did you change the file names/directory at the OS level? You could try removing one from the library and do an update to import it again and see the result.
Removing, and re-adding worked. Thanks.
