Full Version: Change skin from XML?
Having an issue with the new Aeon Skin. After applying the skin, no fonts show up, and I am having issues finding the setting to change back to a working skin.
Is there a way to change the default skin via one of the XML files? If so where is the file located.
guisettings.xml in the userdata folder.
look for the <skin> entry in the <lookandfeel> section.
Thank you! That worked perfectly. Back to a working PM3.HD
Thanks again. Smile
