Can we get a preview before downloading?
I like them. Especially the Alternative one.
Atmospheric instead of Atmosferic?
I can add some other... any feedback is welcome
These are great! I really like 'm a lot.
Would be a tough task to create a full set, if even possible.
My htpc lists about 60 genres, so that would be a hell of a job.
Any additions to this set are of course very welcome. You might consider posting the source, so people can create their own or assist you in completing the set as much as possible.
I'm not using Aeon, but this is the code to get it working in PM3.HD:
<control type="image">
<posx>0</posx>
<posy>0</posy>
<width>400</width>
<height>510</height>
<texture>/path/to/icons/$INFO[Listitem.label,,.png]</texture>
<visible>Container.Content(Genres) + Window.IsVisible(MusicLibrary)</visible>
</control>
As far as i know this code should also work for other skins.
in wich xml do i have to put it in?
tjost Wrote:in wich xml do i have to put it in?
In ViewsFileMode.xml, on line 201 you'll find this code:
<posx>0</posx>
<posy>0</posy>
<width>400</width>
<aspectratio>keep</aspectratio>
<fadetime>IconCrossfadeTime</fadetime>
<texture>$INFO[ListItem.Icon]</texture>
</control>
Change it to this:
<posx>0</posx>
<posy>0</posy>
<width>400</width>
[b]<visible>![Container.Content(Genres) + Window.IsVisible(MusicLibrary)]</visible>[/b]
</control>
[b]<control type="image">
<posx>0</posx>
<posy>55</posy>
<width>400</width>
<height>400</height>
</control>[/b]
Of course, change '/path/to/icons/' to the path where you've stored the icons.
ronie Wrote:These are great! I really like 'm a lot.
<posx>0</posx>
<posy>0</posy>
<width>400</width>
</control>
Please send me the list with the genres that you are using and I will try to do them. I can send you the xcf file if you want or post it here...
I was thinking to make a series for movies as well to match the design...
ronie Wrote:In ViewsFileMode.xml, on line 201 you'll find this code:
<posx>0</posx>
<posy>0</posy>
<width>400</width>
</control>
Change it to this:
<posx>0</posx>
<posy>0</posy>
<width>400</width>
</control>
<posx>0</posx>
<posy>55</posy>
<width>400</width>
</control>[/b]
sorry but in AEON this xml dosent exixts
tash Wrote:Please send me the list with the genres that you are using and I will try to do them. I can send you the xcf file if you want or post it here...
Here's a list of 'offical' genres supported by the id3 tag in mp3's:
http://www.id3.org/id3v2.3.0#head-129376...0288d7c7e7
Like i said, there are a lot of genres, so i would completely understand if you're not looking forward to do them all on your own.
If you would be so kind to post a link to your .xcf file, i would really appreciate it. :-)
Maybe i can find the time to do a few myself.
It would be great if somebody could write a small mod to use these fine posters for Aeon Auriga as it is lacking that. hint hint
tjost Wrote:sorry but in AEON this xml dosent exixts
Nope, in Aeon you would have to change some parts in Viewtype_List.xml.
paul Wrote:It would be great if somebody could write a small mod to use these fine posters for Aeon Auriga as it is lacking that. hint hint
- If you have set 'Use Single Thumbnail For Music Lists' in Advanced Aeon Options, you'll have to modify the code beneath this entry in Viewtype_List.xml:
<!-- SINGLE SQUARE -->
- If you're using multiple icons you'll have to change these parts in Viewtype_List.xml:
<!-- SQUARE: Rolling down -->
<!-- SQUARE: Rolling up -->
<!-- SQUARE: Rolling static -->
Here's how to do it for Single Icons. Look up this code beneath the <!-- SINGLE SQUARE --> entry:
<include>MusicListIcon_SingleThumb</include>
<info>Container.Listitem(0).Icon</info>
<visible>!Control.IsVisible(8001)</visible>
<fadetime>400</fadetime>
</control>
<include>MusicListIcon_SingleGlass</include>
</control>
And change it to this:
<visible>!Control.IsVisible(8001)[b] + ![Container.Content(Genres) + Window.IsVisible(MusicLibrary)][/b]</visible>
</control>
<visible>!Control.IsVisible(8001) [b]+ ![Container.Content(Genres) + Window.IsVisible(MusicLibrary)][/b]</visible>
</control>
<posx>732</posx>
<posy>163</posy>
<height>350</height>
<width>350</width>
<visible>!Control.IsVisible(8001) + Container.Content(Genres) + Window.IsVisible(MusicLibrary)</visible>
</control>[/b]
If you want to do it for the Multiple Icon View, the changes needed should be similar, although a bit more work. ;-)
