Full Version: Remove/change a path to home screen.
Hi There,
Recently I discovered this amazing skin for plex, I like the fact that is really elegant and simple.
There's one thing that I would like to change (if possible);
When I'm at my home screen and I click in to the "movies" section it takes me directly to my movies library like this:
http://www.phycoestudio.com/santa/Picture%201.jpg
http://www.phycoestudio.com/santa/Picture%203.jpg
Then, when I want to go back from my movies to my home screen I have to pass through 2 other menus:
http://www.phycoestudio.com/santa/Picture%204.jpg
http://www.phycoestudio.com/santa/Picture%205.jpg
So, is there a way for me to remove this last 2 steps in the path from movies to my home screen?
Thanks,
Neura.
Use the Esc button.
Thank you for answer. Actually using either the apple remote or the Esc Button gives me the same results.
Maybe I should be more clear; Using the Esc button and the apple remote, gives me the same result of the 2 additional screens. Is there a way to get rid of those screens by doing something with the home.xml?
