2004-08-12, 04:10
2004-08-12, 06:33
that would be the one and only darkie
ts
ts
2004-08-15, 01:45
howcom that normal mov-files on my harddisc play with sound, but as soon as i stream a quicktime file via this script, i don't get any sound?
2004-08-15, 08:21
you need updated xbmc with quicktime support (with the codecs as well).
ts
ts
2004-08-15, 19:00
works like a charm!
great work!
there is however one minor _issue_ using it, you _must_ always choose the video quality. a global setting for that would be very nice.
a nice feature, could be, a options, just to play all the traylers without manual intervention
greetings,
great work!
greetings,
2004-08-16, 02:21
(iafilius @ aug. 15 2004,18:00 Wrote:works like a charm!its easy to modify the script to always stream the large/medium/small file
great work!
greetings,
just open the file .py script with a texteditor, and see if you can do it
2004-08-16, 02:58
my 2 cents - i think that this script could only benefit from a couple changes.
1) the first being imdb interaction. clicking white on the movie, and having xbmc do the same thing as a movie. even creating a trailers4.db file. then a scan button would be useful.
2) if it is downloading imdb info, thumbnails along with thumbnail views would only make sense.
3) a progress bar after clicking a movie would be nice, instead of the scrolling test, for the less tech savvy users.
4) a global setting for quality would be nice.
bugs - some movies seem to not start streaming correctly. the only two i can think of are meet the fockers, and a dirty shame.
awesome script darkie and props to chokemaniac for skin work, on this and xmovieguide.
2004-08-17, 09:42
hi,
i run into a problem...
script runs fine and i got the correct list of trailer. when i try to open a trailer the screen flickers (a popup shows 0.5sec) and nothing happens :help: :help:
2004-08-17, 14:47
hi,
i use the xbmc from yesterday and i can play mov files with sounds... no problem at all but i canĀ“t play them out of the python script :-(
2004-08-17, 14:58
you select a .mov file out of the python script and... don't run?
post xbmc.log
2004-08-17, 15:08
hi,
okay in 2 hours when i arrive from office @ home :-)
i hope it will help...
2004-08-17, 22:35
17-08-2004 22:24:19 info -->python initialized<--
17-08-2004 22:24:19 error texture manager unable to load file: q:\skin\mediacenter\media\button-nofocus.jpg
17-08-2004 22:24:22 info fetching htmlpage : http://www.apple.com/trailers/home/externala_2wide.js
17-08-2004 22:24:23 info found 10 exclusive trailers
17-08-2004 22:24:23 info found 36 new trailers
17-08-2004 22:24:23 info parsing data for distributor : 20th century fox
17-08-2004 22:24:23 info found 14 trailers
17-08-2004 22:24:23 info parsing data for distributor : disney
17-08-2004 22:24:23 info found 4 trailers
17-08-2004 22:24:23 info parsing data for distributor : dreamworks skg
17-08-2004 22:24:23 info found 5 trailers
17-08-2004 22:24:23 info parsing data for distributor : fine line features
17-08-2004 22:24:23 info found 2 trailers
17-08-2004 22:24:23 info parsing data for distributor : focus features
17-08-2004 22:24:23 info found 3 trailers
17-08-2004 22:24:23 info parsing data for distributor : fox searchlight
17-08-2004 22:24:23 info found 8 trailers
17-08-2004 22:24:23 info parsing data for distributor : lions gate films / artisan
17-08-2004 22:24:23 info found 7 trailers
17-08-2004 22:24:23 info parsing data for distributor : mgm/united artists
17-08-2004 22:24:23 info parsing data for distributor : miramax
17-08-2004 22:24:23 info found 9 trailers
17-08-2004 22:24:23 info parsing data for distributor : new line
17-08-2004 22:24:23 info found 6 trailers
17-08-2004 22:24:23 info parsing data for distributor : paramount
17-08-2004 22:24:23 info found 10 trailers
17-08-2004 22:24:23 info parsing data for distributor : paramount classics
17-08-2004 22:24:23 info parsing data for distributor : sony pictures
17-08-2004 22:24:23 info found 12 trailers
17-08-2004 22:24:23 info parsing data for distributor : sony pictures classics
17-08-2004 22:24:23 info parsing data for distributor : touchstone
17-08-2004 22:24:23 info parsing data for distributor : universal
17-08-2004 22:24:23 info parsing data for distributor : warner bros
17-08-2004 22:24:23 info found 11 trailers
17-08-2004 22:24:23 info parsing data for distributor : warner independent pictures
17-08-2004 22:24:23 error texture manager unable to load file: q:\skin\mediacenter\media\button-nofocus.jpg
17-08-2004 22:24:28 info all button pressed
17-08-2004 22:24:32 info fetching htmlpage : http://www.apple.com/trailers/wb/alexander
17-08-2004 22:24:34 info link to another page found, retrieving new page
17-08-2004 22:24:34 info fetching htmlpage : http://www.apple.com/trailers/wb/alexander/large.html
17-08-2004 22:24:35 info getting movielink
17-08-2004 22:24:35 info link = http://movies.apple.com/movies/wb/alexan...er_480.mov
17-08-2004 22:24:35 info got movielink
17-08-2004 22:24:35 error texture manager unable to load file: q:\skin\mediacenter\media\button-nofocus.jpg
okay the skin is my problem i guess.... but where could i start scripts with "prokect mahem" skin
2004-08-17, 22:38
hi,
okay i changed my skin and everything runs fine now .... :kickass:
2004-08-18, 08:41
hi,
where could i start scripts in "project mahem" skin
