News:
June 22, 2009 - Official plugin released! The current thread replaces
this one.
About:
The plugin interfaces the µTorrent WebUI and allows for individual or complete torrent control.
Individual torrent functions:
- Pause
- Resume
- Start
- Stop
- Force Start
- Remove
- Remove and Remove Data
Complete torrent list functions:
- Pause All
- Resume All
- Stop All
- Start All
- Limit Upload & Download Speeds
- Add Files (from Torrents dir.)
Screenshots:
Installation:
Downloads:
June 22, 2009 -
version 1.2.0.
Nice Work, but I don't understand to enable TOKEN auth. in WEBGUI.
Maybe there is a german link, I may better understand.
In the preferences section the bottom option is advanced. Scroll down to the bottom of the items listed in the right hand pane and you should see: webui.token_auth. Just set this to enabled.
If you dont see this option then you will need to use the Non-Token Auth version.
THX
now Iunderstand but, can't find this option, also a version without TOKEN auth.
Is there a download link for the WEBGUI with token.auth?
Very nice work ;-)
Had one minor issue - settings refused to save from the XBMC GUI for some reason (Linux variant).
Spent a few minutes fiddling with permissions, to no great effect, so went `quick & dirty` and changed the settings file manually in a text editor from OS.
Now it works perfectly.
is there any kind of plugin that can search a torrent site from within xbmc which could be placed in a folder monitored by utorrent on the serving PC to allow for full torrent intergration?
Justcop Wrote:is there any kind of plugin that can search a torrent site from within xbmc which could be placed in a folder monitored by utorrent on the serving PC to allow for full torrent intergration?
Yes, chunk 1970 created
these.
I can't get this to work. When I click on it I get a dialouge box saying loading directory, retrieved 0 items.
This stays on 100% and stops with python script failed.
Are there anyother dependencies I am perhaps missing. Python is installed because other plugins work fine.
http://pastebin.com/m4e2df880
token is enabled in utorrent (through wine)
but I can't even get to the point to set the settings on the xbmc machine.
f3ar007 Wrote:
The settings must be changed in the actual uTorrent application, not in WebUI.
Now I dont understand anything.
It also don't work for me.
I got all errors the others, too.
Pluginsettings would not besaved :-(
Settings are checked!
Settings were set, but didn't saved after press "OK"
I tried to hardcode settings in /resources/settings.xml (also not taking from there).
Also dialogbox crash with a python error.
I am Using XBOX with Daily Build from last Week at "xTV"-Skin. I copied the Plugin to VIDEO Section in XBMC.
This turned out pretty nice. Good work!
Works in Windows here, but I believe I'm having the same Xbox issues as everyone else.
nice, will try it later
What is the setting "torrent directory" for?
I saw this
Quote:Add Files (from Torrents dir.)
Is this just a local torrent dump site to just send to utorrent?
