Full Version: XBMC Jaunty Nvidia crashes at start
Pages: 1 2
I installed XBMC on my Linux 9.04 from this place
https://launchpad.net/~team-xbmc/+archive/jaunty-ppa
and when I start it, it displays a screen for a second and dies. The terminal says the following, but I can't figure out whats wrong. Using the nvidia driver that ubuntu recomended:
Thanks for any help....
domagoj@ubuntu:~$ xbmc
The XBMC_HOME environment variable is not set.
*** glibc detected *** /usr/share/xbmc/xbmc.bin: realloc(): invalid old size: 0x08bea1f8 ***
======= Backtrace: =========
/lib/tls/i686/cmov/libc.so.6[0xb747f604]
/lib/tls/i686/cmov/libc.so.6[0xb74831b1]
/lib/tls/i686/cmov/libc.so.6(realloc+0x106)[0xb7483ee6]
/lib/libnss_wins.so.2(Realloc+0xc3)[0xb47208cd]
/lib/libnss_wins.so.2(realloc_array+0x6a)[0xb47209c0]
/lib/libnss_wins.so.2(debug_add_class+0x7b)[0xb4707f50]
/lib/libnss_wins.so.2(debug_init+0x3b)[0xb47080a4]
/lib/libnss_wins.so.2(setup_logging+0x26)[0xb4708e37]
/lib/libnss_wins.so.2(_nss_wins_gethostbyname_r+0xf3)[0xb461c70e]
/lib/libnss_wins.so.2(_nss_wins_gethostbyname2_r+0x4f)[0xb461cca3]
/lib/tls/i686/cmov/libc.so.6[0xb74d823a]
/lib/tls/i686/cmov/libc.so.6(getaddrinfo+0x1bf)[0xb74d9c7f]
/usr/lib/libcurl.so.4[0xb7f2e487]
/usr/lib/libcurl.so.4[0xb7f03d96]
/usr/lib/libcurl.so.4[0xb7f163ca]
/usr/lib/libcurl.so.4[0xb7f1680f]
/usr/lib/libcurl.so.4[0xb7f293e9]
/usr/lib/libcurl.so.4(curl_multi_perform+0x59)[0xb7f29979]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl10CReadState10FillBufferEj+0x21e)[0x8668d1e]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl10CReadState7ConnectEj+0xf7)[0x86693c7]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl4OpenERK4CURL+0xc3)[0x866c4f3]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl7ServiceERK7CStdStrIcES4_RS2_+0x6a)[0x866854a]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl3GetERK7CStdStrIcERS2_+0x43)[0x8669a43]
/usr/share/xbmc/xbmc.bin(_ZN24CBackgroundWeatherLoader14GetInformationEv+0x161)[0x8889b01]
/usr/share/xbmc/xbmc.bin(_ZN17CBackgroundLoader7ProcessEv+0x19)[0x88658e9]
/usr/share/xbmc/xbmc.bin(_ZN7CThread12staticThreadEPv+0x68)[0x888a268]
/usr/share/xbmc/xbmc.bin[0x88189c6]
/usr/lib/libSDL-1.2.so.0[0xb7d0583b]
/usr/lib/libSDL-1.2.so.0[0xb7d5371d]
/lib/tls/i686/cmov/libpthread.so.0[0xb730d4ff]
/lib/tls/i686/cmov/libc.so.6(clone+0x5e)[0xb74f449e]
======= Memory map: ========
08048000-08bb3000 r-xp 00000000 08:01 2598354 /usr/share/xbmc/xbmc.bin
08bb3000-08bb5000 r--p 00b6b000 08:01 2598354 /usr/share/xbmc/xbmc.bin
08bb5000-08bec000 rw-p 00b6d000 08:01 2598354 /usr/share/xbmc/xbmc.bin
08bec000-08c66000 rw-p 08bec000 00:00 0
09052000-094e6000 rw-p 09052000 00:00 0 [heap]
ad263000-b1264000 rw-s 00000000 00:15 61084 /dev/shm/pulse-shm-2616326000
b1264000-b1265000 ---p b1264000 00:00 0
b1265000-b1a65000 rwxp b1265000 00:00 0
b3c00000-b3c21000 rw-p b3c00000 00:00 0
b3c21000-b3d00000 ---p b3c21000 00:00 0
b3de2000-b3de3000 ---p b3de2000 00:00 0
b3de3000-b45e3000 rwxp b3de3000 00:00 0
b45e3000-b47f5000 r-xp 00000000 08:01 115099 /lib/libnss_wins.so.2
b47f5000-b47f6000 ---p 00212000 08:01 115099 /lib/libnss_wins.so.2
b47f6000-b47fa000 r--p 00212000 08:01 115099 /lib/libnss_wins.so.2
b47fa000-b47ff000 rw-p 00216000 08:01 115099 /lib/libnss_wins.so.2
b47ff000-b4800000 rw-p b47ff000 00:00 0
b4800000-b482a000 rw-p b4800000 00:00 0
b482a000-b4900000 ---p b482a000 00:00 0
b492d000-b4934000 r-xp 00000000 08:01 98342 /usr/lib/libtalloc.so.1.2.0
b4934000-b4935000 r--p 00006000 08:01 98342 /usr/lib/libtalloc.so.1.2.0
b4935000-b4936000 rw-p 00007000 08:01 98342 /usr/lib/libtalloc.so.1.2.0
b4936000-b4940000 r-xp 00000000 08:01 132329 /lib/tls/i686/cmov/libnss_files-2.9.so
b4940000-b4941000 r--p 00009000 08:01 132329 /lib/tls/i686/cmov/libnss_files-2.9.so
b4941000-b4942000 rw-p 0000a000 08:01 132329 /lib/tls/i686/cmov/libnss_files-2.9.so
b4950000-b4951000 ---p b4950000 00:00 0
b4951000-b5151000 rwxp b4951000 00:00 0
b5151000-b5179000 r--p 00000000 08:01 2613360 /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
b5179000-b51a1000 r--p 00000000 08:01 2613360 /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
b51a1000-b51c9000 r--p 00000000 08:01 2613360 /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
b51c9000-b51f1000 r--p 00000000 08:01 2613360 /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
b51f1000-b5200000 r--p 00000000 08:01 2613362 /usr/share/xbmc/skin/PM3.HD/fonts/humanist_521_bt.ttf
b5200000-b520f000 r--p 00000000 08:01 2613361 /usr/share/xbmc/skin/PM3.HD/fonts/humanist_521_condensed_bt.ttf
b520f000-b5237000 r--p 00Aborted
Ugh... please read the "how to post a problem in a useful manner" sticky.
althekiller Wrote:Ugh... please read the "how to post a problem in a useful manner" sticky.
And what have I missed, described the error, said it's ubuntu 9.04, from where I installed the app, what video card I have, what else should I put?
I installed it with apt-get after adding and signing sources. I have nvidia accelerated driver, version 180. The app, when I start it, displays the screen for a second and aborts. I believe the reason can be found in the copy of terminal output I put in the previous post.
Didn't see any similar problems somewhere on the net. Just problems with ATI drivers.
You missed about everything important for a developer to see what could be causing your troubles. Go read the sticky again and then provide the following: a debug log, a gdb backtrace - both on a service like pastebin please, don't spam the forums with log output.
What Al meant is provide a FULL debug log on pastebin...not some snippets directly in the post. We don't even know which version you're running.
Haggy Wrote:What Al meant is provide a FULL debug log on pastebin...not some snippets directly in the post. We don't even know which version you're running.
I apologize, I thought debug log and terminal output were the same thing.
So my xbmc.log should be here:
http://d.cl1p.net/xbmc_log/
hm, and here Smile as you prefer http://pastebin.com/m41ce313b
Unfortunately, I don't see anything strange in the logs.. Sad I'm about to go find alternatives to this...
Please search. Pretty sure this has been covered before.
Check your /etc/nsswitch.conf.
Remove the wins in there. This isn't a bug with XBMC. But you are more than welcome to use something else with that attitude.
tslayer Wrote:Please search. Pretty sure this has been covered before.
I have a short fuse. Often blurt out stuff and later regret it. Sorry. But when applications that are said to be stable break on a clean system and a fresh instalation I tend to get a bit nervous, as the reason I formated my Vista partition and put Linux (again), for my would me media/file/application/web/sql home server station...
I managed to get everything but this working, Apache, Mysql, samba server, webmin. Everything but this, and I want it. SO SORRY, PLEASE HELP ME Confused
I actually put wins in there to make samba work with names. Will try to remove it if you say it could help. I searched for a similar problem, but couldn't find anything that would help me. Believe me I search first, and hate to ask for help as I know how it ends up...Oo I'm talking too much... grrr...Angry
Report back after removing wins. Should work after that. Search google and you'll see other programs exhibit the same crashes due to that.
tslayer Wrote:Report back after removing wins. Should work after that. Search google and you'll see other programs exhibit the same crashes due to that.
Hey, reporting back. After I removed wins, the error changed. At the end of xbmc.log at http://pastebin.com/m9c9452 it says SQLite error. I installed Sqlite3, and php-sqlite from synaptic (which weren't installed before) and nothing changed. Any ideas?
domagoj Wrote:Hey, reporting back. After I removed wins, the error changed. At the end of xbmc.log at http://pastebin.com/m9c9452 it says SQLite error. I installed Sqlite3, and php-sqlite from synaptic (which weren't installed before) and nothing changed. Any ideas?
Yaaaaay, I managed to start XBMC, and I'll be nice and post the answer to previous error. So if you get in your xbmc.log error like ERROR: SQLite: SQL error or missing database you have to delete the directory /home/user/.xbmc/userdata
When you delete userdata, restart XBMC and don't ask me why it works? Shocked
Bye and let's waste some time watching movies.... Smile
xbmc 9.04.2+svn21496-jaunty1
kubuntu 9.04
x86_64
installed from xbmc-svn ppa (http://ppa.launchpad.net/team-xbmc-svn/ppa/ubuntu)
svn revision 21496
Happens every time - I launch xbmc, shows the splash screen, checks the DVD (you can hear it started), and closes with just a "aborted" on the terminal.
The xbmc.log is here, and the backtrace here.
Can anyone help me with this? I've tried with the DVDS empty or with a DVD inside, and doesn't change anything. It just aborts as soon as it seems it is about to show the main screen.
Just updated to 9.04.2+svn21650-jaunty1
Now the error is slightly more verbose:
*** glibc detected *** /usr/share/xbmc/xbmc.bin: realloc(): invalid pointer: 0x0000000001293acc ***
/lib/libc.so.6[0x7f4523fd7cb8]
/lib/libc.so.6(realloc+0x2bc)[0x7f4523fdcf3c]
/lib/libnss_wins.so.2(Realloc+0xa6)[0x7f4519ba5b37]
/lib/libnss_wins.so.2(realloc_array+0x44)[0x7f4519ba5c0e]
/lib/libnss_wins.so.2(debug_add_class+0x70)[0x7f4519b8f1b7]
/lib/libnss_wins.so.2(debug_init+0x29)[0x7f4519b8f2f3]
/lib/libnss_wins.so.2(setup_logging+0x10)[0x7f4519b90118]
/lib/libnss_wins.so.2(_nss_wins_gethostbyname_r+0xd2)[0x7f4519abdedc]
/lib/libnss_wins.so.2(_nss_wins_gethostbyname2_r+0x2b)[0x7f4519abe364]
/lib/libc.so.6[0x7f452402d414]
/lib/libc.so.6(getaddrinfo+0x1d2)[0x7f452402eda2]
/usr/lib/libcurl.so.4[0x7f452982f9e7]
/usr/lib/libcurl.so.4[0x7f4529807352]
/usr/lib/libcurl.so.4[0x7f4529817853]
/usr/lib/libcurl.so.4[0x7f4529817c0b]
/usr/lib/libcurl.so.4[0x7f452982aba5]
/usr/lib/libcurl.so.4(curl_multi_perform+0x8b)[0x7f452982b24b]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl10CReadState10FillBufferEj+0x217)[0xa5a7a7]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl10CReadState7ConnectEj+0xed)[0xa5adfd]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl4OpenERK4CURL+0x9e)[0xa5dcfe]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl7ServiceERK7CStdStrIcES4_RS2_+0x6f)[0xa59f8f]
/usr/share/xbmc/xbmc.bin(_ZN5XFILE9CFileCurl3GetERK7CStdStrIcERS2_+0x47)[0xa5b507]
/usr/share/xbmc/xbmc.bin(_ZN24CBackgroundWeatherLoader14GetInformationEv+0x17e)[0xc820de]
/usr/share/xbmc/xbmc.bin(_ZN17CBackgroundLoader7ProcessEv+0x11)[0xc5de01]
/usr/share/xbmc/xbmc.bin(_ZN7CThread12staticThreadEPv+0x5f)[0xc8271f]
/usr/share/xbmc/xbmc.bin[0xc1398f]
/usr/lib/libSDL-1.2.so.0[0x7f45281d44c7]
/usr/lib/libSDL-1.2.so.0[0x7f4528219e29]
/lib/libpthread.so.0[0x7f45238323ba]
/lib/libc.so.6(clone+0x6d)[0x7f4524045fcd]
00400000-01043000 r-xp 00000000 08:06 1069148                            /usr/share/xbmc/xbmc.bin
01243000-0124b000 r--p 00c43000 08:06 1069148                            /usr/share/xbmc/xbmc.bin
0124b000-01295000 rw-p 00c4b000 08:06 1069148                            /usr/share/xbmc/xbmc.bin
01295000-01316000 rw-p 01295000 00:00 0
02d03000-03519000 rw-p 02d03000 00:00 0                                  [heap]
40409000-4040b000 rwxp 00000000 00:0f 765                                /dev/zero
40ee7000-40f65000 rw-p 00000000 00:0f 765                                /dev/zero
7f4514000000-7f4514029000 rw-p 7f4514000000 00:00 0
7f4514029000-7f4518000000 ---p 7f4514029000 00:00 0
7f4519866000-7f451986e000 r-xp 00000000 08:06 641911                     /usr/lib/libtalloc.so.1.2.0
7f451986e000-7f4519a6d000 ---p 00008000 08:06 641911                     /usr/lib/libtalloc.so.1.2.0
7f4519a6d000-7f4519a6e000 r--p 00007000 08:06 641911                     /usr/lib/libtalloc.so.1.2.0
7f4519a6e000-7f4519a6f000 rw-p 00008000 08:06 641911                     /usr/lib/libtalloc.so.1.2.0
7f4519a6f000-7f4519c9d000 r-xp 00000000 08:06 931517                     /lib/libnss_wins.so.2
7f4519c9d000-7f4519e9d000 ---p 0022e000 08:06 931517                     /lib/libnss_wins.so.2
7f4519e9d000-7f4519ea5000 r--p 0022e000 08:06 931517                     /lib/libnss_wins.so.2
7f4519ea5000-7f4519ead000 rw-p 00236000 08:06 931517                     /lib/libnss_wins.so.2
7f4519ead000-7f4519eae000 rw-p 7f4519ead000 00:00 0
7f4519eae000-7f4519eb0000 r-xp 00000000 08:06 929407                     /lib/libnss_mdns4_minimal.so.2
7f4519eb0000-7f451a0af000 ---p 00002000 08:06 929407                     /lib/libnss_mdns4_minimal.so.2
7f451a0af000-7f451a0b0000 rw-p 00001000 08:06 929407                     /lib/libnss_mdns4_minimal.so.2
7f451a0b0000-7f451a0b1000 ---p 7f451a0b0000 00:00 0
7f451a0b1000-7f451a8b1000 rwxp 7f451a0b1000 00:00 0
7f451a8b1000-7f451a8b2000 ---p 7f451a8b1000 00:00 0
7f451a8b2000-7f451b0b2000 rwxp 7f451a8b2000 00:00 0
7f451b0b2000-7f451b0da000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b0da000-7f451b102000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b102000-7f451b12a000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b12a000-7f451b152000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b152000-7f451b161000 r--p 00000000 08:06 1208978                    /usr/share/xbmc/skin/PM3.HD/fonts/humanist_521_bt.ttf
7f451b161000-7f451b170000 r--p 00000000 08:06 1208979                    /usr/share/xbmc/skin/PM3.HD/fonts/humanist_521_condensed_bt.ttf
7f451b170000-7f451b198000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b198000-7f451b1c0000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b1c0000-7f451b1e8000 r--p 00000000 08:06 1208950                    /usr/share/xbmc/skin/PM3.HD/fonts/LiberationSans-Regular.ttf
7f451b1e8000-7f451b1e9000 ---p 7f451b1e8000 00:00 0
7f451b1e9000-7f451b9e9000 rwxp 7f451b1e9000 00:00 0
7f451b9e9000-7f451b9eb000 r-xp 00000000 08:06 230715                     /usr/lib/gconv/ISO8859-1.so
7f451b9eb000-7f451bbea000 ---p 00002000 08:06 230715                     /usr/lib/gconv/ISO8859-1.so
7f451bbea000-7f451bbeb000 r--p 00001000 08:06 230715                     /usr/lib/gconv/ISO8859-1.so
7f451bbeb000-7f451bbec000 rw-p 00002000 08:06 230715                     /usr/lib/gconv/ISO8859-1.so
7f451bdee000-7f451bdef000 rw-p 7f451bdee000 00:00 0
7f451bdef000-7f451bfef000 rw-s c1dc3000 00:0f 14217                      /dev/nvidia0
7f451bfef000-7f451bff3000 rw-s d38e8000 00:0f 14217                      /dev/nvidia0
7f451bff3000-7f451c0f3000 rw-s cb877000 00:0f 14217                      /dev/nvidia0
7f451c0f3000-7f451c245000 rw-s 00000000 00:09 76742684                   /SYSV00000000 (deleted)
7f451c245000-7f451c325000 r-xp 00000000 08:06 1316743                    /usr/share/xbmc/system/ImageLib-x86_64-linux.so
7f451c325000-7f451c525000 ---p 000e0000 08:06 1316743                    /usr/share/xbmc/system/ImageLib-x86_64-linux.so
7f451c525000-7f451c529000 r--p 000e0000 08:06 1316743                    /usr/share/xbmc/system/ImageLib-x86_64-linux.so
7f451c529000-7f451c52e000 rw-p 000e4000 08:06 1316743                    /usr/share/xbmc/system/ImageLib-x86_64-linux.so
7f451c52e000-7f451c532000 rw-p 7f451c52e000 00:00 0
7f451c532000-7f451c53e000 r-xp 00000000 08:06 931020                     /lib/libnss_files-2.9.so
7f451c53e000-7f451c73d000 ---p 0000c000 08:06 931020                     /lib/libnss_files-2.9.so
7f451c73d000-7f451c73e000 r--p 0000b000 08:06 931020                     /lib/libnss_files-2.9.so
7f451c73e000-7f451c73f000 rw-p 0000c000 08:06 931020                     /lib/lAborted
If needed, I can supply again the xbmc.log and the gdb backtrace.
Updated to 9.04.2+svn21688-jaunty1, still fails the same way.
Pages: 1 2
