Awesome! Can you put this in the SVN Repo so we can use it through the installer?
Thanks for the plugin I love being able to watch these documentaries really glad to see this after the johnlocker plugin stopped working keep up the great work
thanks for the feedbacks.
If there is no major problems with the plugin, I will submit to the repo soon. For the time being, go to my link.
OTR, there is a video plugin of 66stage.com which i revived to work with its impressive list of documentaries videos (1000+). For those who loves docs videos.
hi, i love this plugin. unfortunately it seems to have some issue with some content. atleast googlevideo stuff is affected.
updated to clean bugs with Google vids and also added Youtube playlist.
thanks for the feedback.
fixed issues with retrieving videos from multiple sources. 21/01/10
you have choice of hi and low bitrate streams from youtube now. enjoy!
Fixed (Rev. 02) to cope youtube (playlist included) changes recently. Enjoy!
thanks for the update love this plugin
Hi whenever I run this script, all I get error script failed.
I am going the following is the debug info
13:03:42 T:1584 M:1805946880 NOTICE: :
13:03:42 T:1584 M:1805946880 NOTICE: 'module' object has no attribute 'argv'
13:03:42 T:1584 M:1805946880 ERROR: Scriptresult: Error
13:04:03 T:4164 M:1802924032 NOTICE: -->Python Interpreter Initialized<--
13:04:03 T:4164 M:1800683520 NOTICE: Traceback (most recent call last):
13:04:03 T:4164 M:1800683520 NOTICE: File "C:\Program Files\XBMC\scripts\topdocumentaryfilms\default.py", line 454, in ?
13:04:03 T:4164 M:1800683520 NOTICE: params=get_params()
13:04:03 T:4164 M:1800683520 NOTICE: File "C:\Program Files\XBMC\scripts\topdocumentaryfilms\default.py", line 401, in get_params
13:04:03 T:4164 M:1801072640 NOTICE: paramstring=sys.argv[2]
13:04:03 T:4164 M:1801072640 NOTICE: AttributeError
13:04:03 T:4164 M:1801072640 NOTICE: :
13:04:03 T:4164 M:1801072640 NOTICE: 'module' object has no attribute 'argv'
13:04:03 T:4164 M:1801072640 ERROR: Scriptresult: Error
13:04:38 T:5324 M:1808863232 NOTICE: -->Python Interpreter Initialized<--
13:04:39 T:5324 M:1806299136 NOTICE: Traceback (most recent call last):
13:04:39 T:5324 M:1806299136 NOTICE: File "C:\Program Files\XBMC\scripts\topdocumentaryfilms\default.py", line 454, in ?
13:04:39 T:5324 M:1806299136 NOTICE: params=get_params()
13:04:39 T:5324 M:1806299136 NOTICE: File "C:\Program Files\XBMC\scripts\topdocumentaryfilms\default.py", line 401, in get_params
13:04:39 T:5324 M:1806299136 NOTICE: paramstring=sys.argv[2]
13:04:39 T:5324 M:1806299136 NOTICE: AttributeError
13:04:39 T:5324 M:1806299136 NOTICE: :
13:04:39 T:5324 M:1806299136 NOTICE: 'module' object has no attribute 'argv'
13:04:39 T:5324 M:1806299136 ERROR: Scriptresult: Error
this sounds like a cool script..please help!
hell_spawn27 Wrote:Hi whenever I run this script, all I get error script failed.
Please place it in the PLUGIN folder not script. If you still in the same road, let me know or else enjoy.
any chance you could add support for the missing docu sources, or are there technical reasons for their non-workie ?
spiff Wrote:any chance you could add support for the missing docu sources, or are there technical reasons for their non-workie ?
if the video is not pulling from ytube or google, ur out of luck spiff. Technically any video source can be supported but perhaps consistency is a pre-requisite to pursue further. Btw, which doc are you interested with?
uhm, i can't recall any specifics up front, but my guesstimate is that maybe 15-20% won't work (empty listings). shouldn't be hard to find one which does that.
