Full Version: Deselecting a view from View Options
Hi there;
I'm using XBMC 9.04.1 and few days back I selected the 'List' view option in the 'By Genre' listing. I much preferred the original black background and smooth text scrolling (no view option selected).
The problem here is that there is no visible way to clear selection under the View Options menu, initially after a fresh install there's no view option selected for the Movies category listing (i.e.By Genre, By Actor, By Director...etc.) so you get the black background but after you select one of the view options (i.e. List, Info List, Media Preview...etc.) you're stuck with one of these view options!
Is there anyway I can edit an xml config file somewhere to clear view options in the Movies category listing? Eek
m
