@mikkle: Thanks. Sure, always open for new ideas
@Starchild: The view in video mode will be gone soon and the other view will be used, which has fast scrolling out of the box. Rarfiles see
here. Xbox is indeed another issue, but #32 is the one I converted for your problem.
Since the 5.7 I have had 0 problems at all using the remote with my xbox, increasing the timeout to 30 seconds seems to have done the trick although it does take a while or the lists to load there's no more problems or crashes
I have noticed some small bugs recently relating to podcasts, I'll update the google code page later.
Great work everyone
Added: "Hide artists who appear only on compilations" (Setting read from XBMC)
Fixed: Album and song listing should now be faster
Fixed: Weird remote-moving-down-bug
Download v0.5.8
@seaweeduk: Can you test with this version if you see any speedup with your Xbox?
@freezy: Got a similar problem with folders. see updated
ticket#43.
freezy Wrote:Added: "Hide artists who appear only on compilations" (Setting read from XBMC)
Download v0.5.8
I'll post an update once I get home using a stop watch to see the difference between the two if there is one
Thought this wasn't worth opening an issue for since the old music and video views will be gone soon but I wanted to let you know that video plugins don't work properly currently, rss feeds also display on the remote incorrectly and crash now playing.
Good news is that my XBMC doesn't freeze anymore with v0.5.8 when I access Music Library, and "Albums..." goes to "Albums (0)" much faster.
EDIT: Actual, I can use "Artists (6467)", "Genres (75)" and "/", which I couldn't use before. Just "Albums" that doesn't work for me now.
Is it possible to get a rolling text for the selected items?
//Cheers StarChild
StarChild Wrote:Good news is that my XBMC doesn't freeze anymore with v0.5.8 when I access Music Library, and "Albums..." goes to "Albums (0)" much faster.
Are you still testing on the ~3000 albums db?
Did freezy's latests optimizations solve the out-of-mem-crash?
:O) mikkle
mikkle Wrote:Are you still testing on the ~3000 albums db?
:O) mikkle
Yes ~3000 albums. I can't see in the changelog that it should been fixed? But it's overall better.
It does crash, but I cant really reproduce it because it seems that it's a little here and there in Music, at least I can use the other alternatives to access my music.
There are albums missing I just noticed.
Download v0.5.8
maybe a slight speedup for the artist and genre views however albums view doesn't work at all just shows albums(0) and doesn't time out, selecting an artist also then causes the same behaviour.
xbmc log here incase it helps
http://pastebin.ca/1636247
edit: also here's a log of the previous version with the working album view looks like it takes about 28 seconds
http://pastebin.ca/1636270
That's pretty weird. It seems that VA albums are not listed in album view, but zero albums is pretty strange. Basically it means that
SELECT idAlbum, strAlbum, strArtist, iYear, strThumb FROM albumview WHERE albumview.strAlbum <> ''
doesn't return anything at all.
Can you either verify that using a SQLite client, or can you do the following:
- Start XBMC
- Go to music library mode -> Albums
- Open up XBMC Remote, list albums (where you get 0 albums)
- Send me the XBMC log.
The idea is to see what query XBMC runs where you see your albums compared to what XBMC Remote runs. Should both be in XBMC's log.
freezy Wrote:That's pretty weird. It seems that VA albums are not listed in album view, but zero albums is pretty strange. Basically it means that Code:
- Start XBMC
doesn't return anything at all.... so thats why its so fast
So any suggestion to a SQLite client that can sen query commands? Tried SQLiteSpy, but don't understand how to query.
For Windows you can get a 30-day trial of SQLite Maestro. Drag and drop your musicdb.db3 into the prog, open a query window and copy+paste the query mentioned above. Hit F9 to run it.
SELECT idAlbum, strAlbum, strArtist, iYear, strThumb FROM albumview WHERE albumview.strAlbum <> '' :
13281 rows fetched (0,31 sec)
XBMC Debug Log
SELECT a.idAlbum, a.strAlbum, i.strArtist, a.iYear, ( SELECT p.strPath FROM song AS s, path AS p WHERE s.idPath = p.idPath AND s.idAlbum = a.idAlbum LIMIT 1 ) FROM album AS a, artist AS i WHERE a.idArtist = i.idArtist ORDER BY i.strArtist ASC :
13698 rows fetched (280,51 sec)
So that's 13k albums instead of 3k suddenly? Now I understand you're having memory problems
What does
http://xbox/xbmcCmds/xbmcHttp?command=QueryMusicDatabase(SELECT%20idAlbum,%20strAlbum,%20strArtist,%20iYear,%20strThumb%20FROM%20albumview%20WHERE%20albumview.strAlbum%20<>%20'')
return? A list with something, or nothing? Need to
view source in browser, since it's in XML.
