2009-09-05, 10:28
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
2009-09-05, 10:32
freezy Wrote:Did you allow the event client connect from other hosts than local xbmc? It's a setting under network, event server.
Oh, I did not. Thanks a lot. Its working now.
2009-09-05, 10:38
Had the same problem
2009-09-05, 13:16
ccMatrix Wrote:I just updated to the latest version and this is really amazing. I used the Boxee/XBMC Remote from the Market before and this one is so much better. Will there be a release to the Android Market as well (would help with keeping up-to-date)?
Definatly, we will just bash some bugs and then probably start releasing on the market.
2009-09-05, 14:16
Ok, in r66 all remote buttons work perfect, only rewind button image changes in play image.
Now playing works perfect with the xbox.
Through imo the thumb could be bigger and when song title is 2 rows the time bar goes half out of screen.
(Thumbs are default in xbox userdata 192x192 other platforms 512x512)
With windows thumb is bigger, almost full width but only schows the thumb no info/buttons/bar.
And still remote doesn't work in windows, very strange
Tried default keymap, default guisettings, network settings, etc.......
Edit: nevermind got it working
Oh and btw in XBMC web server port is default 80. not 8080
Please consider display<fullscreen> button and scrollball is way to fast.
edit 2:
Hey, my custom d=<fullscreen> on keyboard works now !!
edit 2:
2009-09-05, 14:35
Waffa Wrote:Oh and btw in XBMC web server port is default 80. not 8080
On Xbox yes, on windows / linux / osx 8080 is the default.
Also the scaling of the nowplaying picture is abit weird in r66, I just got it finished in that rev. new version 0.2.2 should have it fixed.
2009-09-05, 15:00
Topfs2 Wrote:On Xbox yes, on windows / linux / osx 8080 is the default.`
Thx, but are you sure about port 8080.
Renamed guisettings on windows so all settings are default and port webserver is 80 or this must be changed recently..
2009-09-05, 15:56
Waffa Wrote:`
Well I'll give you win32 it's 80.
So on (since I'm a linux person) the important os's it's 8080, hehe
EDIT: new version 0.2.3 which should be snappier.
2009-09-05, 16:40
OOh, there's already 0.2.3
0.2.2 Now playing was good thumb only browsing files became very slow.
But let's try 0.2.3
edit:
Solved in 0.2.3
But let's try 0.2.3
edit:
Solved in 0.2.3
2009-09-05, 20:21
Nice , that i can use the menu button in home screen.
I would like to use it in every screen and that there were functions been added.
so it would have:
-settings
-exit
-remote
-video
-music
-pictures
-now playing
in future :
- movies
-tv shows
-music library
And have the ability to back out to whatever ...very fast.
Now I have to push the back button many times to back out my files to go to remote function.
so it would have:
-settings
-exit
-remote
-video
-music
-pictures
-now playing
in future :
- movies
-tv shows
-music library
2009-09-06, 02:09
Waffa Wrote:Nice , that i can use the menu button in home screen.
so it would have:
-settings
-exit
-remote
-video
-music
-pictures
-now playing
in future :
- movies
-tv shows
-music library
Noted, Sounds like a very good idea to have easy acces to some of the views via menu button, will look into it tommorrow and hopefully have it ready soon.
Also both me and freezy have discussed a UI redo soon so if anyone have any additions or pointers on the UI that would be most awesome, and if anyone could do graphics that would ofcourse be most awesome.
Cheers,
Tobias.
2009-09-06, 20:55
So I took the initiative and added the app menu items as suggested by waffa, also moved the media list fetches out of UI thread as suggested on swedroid.se
Also as a really beta purpose one can try freezy's awesome album grid in 0.2.4 (app menu inside of music to change view)
Cheers,
Tobias
Cheers,
Tobias
2009-09-06, 21:30
WOW, this looks very very awesome
Thanx testing now
edit:
Lol still extracting thumbs, got a big music library. looks so freaking
Thanx testing now
edit:
2009-09-07, 00:52
Not getting a menu in the music section when i press menu, an i doing something wrong? Upgraded to 0.2.4 but dosnt seem to work for me :/
The rest works like the dream tho The remote seems a little buggy ~(the rewind changes to a play button when you oress it, and dosnt change back after pressing it) ill report anything else as i find it (HTC Hero with a Xbox for your info)
2009-09-07, 01:34
I don't have an Android device (but I want one!) and I haven't read through every post so forgive me if this has already been posted or added as a feature.
I noticed in a screenshot that it's asking for the IP address of the machine running XBMC, wouldn't it be convenient to work with host names instead? You could connect to "Happy Xbox" instead of "192.168.1.100". Then, as the IP may change if the machine is using DHCP, you wouldn't need to change the address.
