2009-09-24, 09:41
2009-09-24, 09:41
2009-09-24, 10:51
looks very nice! i like the idea. ;-)
you may want to post the xml code you're using, so others can try it too.
cheers.
cheers.
2009-09-24, 11:00
ronie Wrote:looks very nice! i like the idea. ;-)
cheers.
I don't use any custom xml ... i don't get what you mean.
2009-09-24, 11:10
ah..i get it. i thought you were using some xml code to display the images on the moviescreen.
2009-09-24, 11:57
ronie Wrote:ah..i get it. i thought you were using some xml code to display the images on the moviescreen.
That's a good idea.. how would you stretch it out of proportions to fit the screen and create "3d" effect?Is that at all possible?
Cheers
Zeljko
2009-09-24, 12:13
I'd love to see this work in a dynamic way with something like the extrathumbs theory from AEON.
2009-09-24, 14:13
did you make it look 3d? it looks great
2009-09-24, 14:47
Amet Wrote:That's a good idea.. how would you stretch it out of proportions to fit the screen and create "3d" effect?Is that at all possible?
Cheers
Zeljko
maocul Wrote:I'd love to see this work in a dynamic way with something like the extrathumbs theory from AEON.
like this?: http://www.youtube.com/watch?v=k-bqU8xLEt4
2009-09-24, 15:16
ronie Wrote:like this?: http://www.youtube.com/watch?v=k-bqU8xLEt4
yeah, exactly...But what I am thinking is that when you scrolling through the DB, it wouldn't change the whole Fanart background, instead just the picture in the screen.
I know that the Transparency! is Fanart skin and I love it, just thinking if something like this would be possible and if it would look neat.
Cheers
Zeljko
2009-09-24, 17:40
2009-09-24, 18:03
I love this idea and I understand the logic but did you actually get this to work or are they fake videos for demonstration ?
If you actually did it, how?
I know I'm new to all this but I can't even get a PNG to show up as a backdrop, let alone showing fanart behind it...
2009-09-24, 21:33
it might not be visible on screens with lower contrast ratio, but there's a big darker black bar on the left side of the image, here's the fixed 1080p version of the picture without black bar
Edit: the selection of the transparent part of the image is more accurate on the original picture, I don't know how to select it that accurately (i'm not very good with gimp...). if someone could fix the selection too, that would be great.
2009-09-25, 00:11
jpf55 Wrote:I love this idea and I understand the logic but did you actually get this to work or are they fake videos for demonstration ?
i don't produce fakes. everything's real. ;-)
jpf55 Wrote:If you actually did it, how?
by putting a multiimage control behind the backdrop and applying the animated background effects that are already in the skin.
it will get the fanart from xbmc's cache folder (userdata/Thumbnails/Video/Fanart)
jpf55 Wrote:I know I'm new to all this but I can't even get a PNG to show up as a backdrop, let alone showing fanart behind it...
i will have to clean up the code a bit and do some more testing. if i'm done i'll post it here.
2009-09-25, 00:12
2009-09-25, 03:04
That 'Ken Burns' demo you had looked pretty sharp...
