2009-09-28, 16:45
Pages: 1 2
2009-09-28, 18:43
take a look in the
skin/Rapier/720p directory, specifically the file named Font.xml . You can modify the sizes of the various fonts there.
jw
jw
2009-09-29, 01:31
Brilliant, will do! thanks
2009-09-29, 02:13
just implemented the 4x3 code from Transparency font.xml and of course the fonts themselves. Looks much much better, so much easier on the eyes hehe thanks!
2009-09-29, 05:43
Rather than hack into the Font.xml to get larger fonts, it will be a better idea if the user can chgane the font sizes within the skin. This can be implemented as a skin option with a listing of the font descriptions and size options.
2009-09-29, 05:44
logggio Wrote:just implemented the 4x3 code from Transparency font.xml and of course the fonts themselves. Looks much much better, so much easier on the eyes hehe thanks!
Do you mind posting that so others can use it too? Thanks
2009-09-29, 05:45
ck_xbmc Wrote:Rather than hack into the Font.xml to get larger fonts, it will be a better idea if the user can chgane the font sizes within the skin. This can be implemented as a skin option with a listing of the font descriptions and size options.
That would be sooo excellent if this is possible..
2009-09-29, 06:55
That's what i did... You can choose between the default font, Arial 4x3 & default 4x3. Sure i can upload it. Just give me a minute and i'll figure something out :-)
2009-09-29, 07:06
Here ya go guys. http://www.mediafire.com/download.php?mmlymggyujw
2009-10-01, 18:20
logggio Wrote:Here ya go guys. http://www.mediafire.com/download.php?mmlymggyujw
Thanks a bunch, this helps alot! I'm still gonna try to figure out how to make it even bigger...
2009-10-01, 18:39
Yes, would love that too. Other skins already have it and although my HD-ready plasma is 42", it has a strange resolution 1024 x 1280 (no I did not put that in reverse) which causes letters become too thin.
2009-11-04, 10:50
link is dead, think you can reupload this?
thanks!
2009-11-26, 00:44
mrplow Wrote:link is dead, think you can reupload this?
thanks!
Would also appreciate a link, I'm using the skin on an XBOX on a non HD resolution screen and the fonts just slightly too small at times.
2009-11-26, 04:12
I think this is what you're after...
http://www.mediafire.com/file/alymzzttnz...r Font.zip
haven't tried it with the newest rapier yet though...
2009-11-26, 18:06
wannabegt4 Wrote:I think this is what you're after...
Thanks seems to work ok but it messes up the video library appearance too much for my liking.
I'm gonna have a play around in a few days and see if I can come up with a font combination that looks good and is still readable on a non hd display. I'll post the results here for other XBOX owners depending on how it goes.
Pages: 1 2
